Question about Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi 6252 no power light - Zanussi 23 in. ZDT6252 Built-in Dishwasher
2 Suggested Answers
Anonymous
SOURCE:
Anonymous
SOURCE: zanussi zdt 6252
I had the same problem with Zanussi ZDT 6252. To fix it, turn power on, close door fully, then open door, turn off then turn back on again. If you follow this sequence the machine is reset and you can select programs again.
Posted on Feb 15, 2009
My Zanussi ZDC 37200W has no power
Go to the self help section of repairclinic.com Enter you model number for specific trouble shooting advice on your appliance.
May 14, 2015 | Zanussi Dryers
My zanussi ZDT 6252 has rinse and hold and intensive lights flashing and is humming
Have you proper water pressure or is the water tap turned on or kinked? If so - fix it and try again.
Dec 13, 2014 | Zanussi Washing Machines
Zanussi ZDT 6252 dishwasher will not work
Almost certainly the control board has gone faulty. The favorite is the transformer burns or the thyristor gets very hot and burns due to a bad solder joint. Quickest no noncense repair is to bite the bullet and install a new board.
Jun 05, 2010 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
My DVD receiver HT762 does not switch ON. initial check on the power supply shows 330V DC on the first power supply. The next supplies using flyback regulator IC 6252 and UC3844 do not work. the voltage at...
Why is there 330 volts? Most recivers work off 250volts AC, so why would it need 330 volts! Seems to me that whatever is producing that 330 volts is the bad guy that is causing the trouble, unless you live in some part of the world that uses a voltage higher than 250!
Jan 27, 2010 | Audio Players & Recorders
Zanussi Aquapulse DE6854 dishwahser programe lights not working
hi
got same probleme with my aquapulse 4744 slimline
Oct 07, 2009 | Electrolux Dishwashers
Just moved in and run the dishwasher
Replace the timer.
Most likely it was broken by someone resetting the timer by hand while the unit was energized.
Always open the door(de-energizes the timer) when you want to make an adjustment to the machine while it's running.
Jun 21, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Changing heating element.
You normally access the element from the side , Be careful of sharp edges . meter it before you start spending money it could be a timer fault also !
Maurice
Feb 15, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi zdt 6252
Dec 26, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi 23 in. ZDT6252 Built-in Dishwasher Logo
108 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Renee Knafel-Bullock
ray gallant
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
