"PE" error:
Water Level Pressure Sensor Error.
1) Verify that the black tube is still connected to the Water Level Sensor at the top of the washer---and to the Air Bell at the bottom of the tub.
2) Remove the black tube from the Water Level Sensor---and blow into tube---to clear a possible blockage. Reconnect and test washer.
3) Water Level Pressure Sensors (6601ER1006E) *rarely* fail.
Draining fault , check pump & filter
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Pe error not clear even replace new sensor
