Possibly is overheating. check all of your vents to make sure that they are not blocked. I have seen some that the vent holes in back were completely covered with lint, because that is where the microwaves pulled the air into the unit to cool the magnetron. If your vents are blocked it cannot pull that air and it will cause a thermostat mounted on the magnetron to over heat and kick it off line. There is also a chance that the thermostat mentioned above is going bad as well. Hope this helps!
