Leveling should be as simple as putting a level on the top of the fridge left to right 1st and then either in or out depending on the way you need to level it. All for feet for the fridge should be able to turn to make adjustments on the leveling height. After you have done the left to right, turn the level front to back and repeat the leveling process by turning the feet on the bottom of the fridge. You may need a wrench because sometimes they become rusted or just tight. Go back and check the front to rear leveling to make sure that it did not change. This leveling process is used on many appliances.
Testimonial: "thankyou so much for your help. I will give it my best effort. I have a spirit level and shifter somewhere in my stuff to do the job. thankyou again... regards Jill"
The front feet under the door opening are adjustable screws. You may have to use a shifter to get them to move as they mat be rusted . adjust so the fridge slopes slightly to the rear. This keeps any moisture on the back wall to drain out the hole and the door will close if left open
