Question about LG Washing Machines
What does code 03 mean on my lg washer wm227hw
Code 03 appeared and the washer wouldn't complete the cycle
  • LG Master
  • 1,150 Answers
Have you checked your LG Washing Machine Manual for a List of Error Codes?
Usually the code is generated by a switch or sensor.
There are several things like water level sense, door closed switches.
Obviously one of these is the cause..... I Know..... But which One!
Posted on Mar 03, 2015
6ya staff
SOURCE:
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
My front loader washing machine suddenly stop working at there is an LE sign
LG, the electronics and appliances conglomerate, manufactures a variety of high-efficiency washing machines. Whether you have a front- or top-loading model, your LG washer is equipped with an error-monitoring system. When the LE code appears in your display, it indicates a problem with the motor. The problem can be related to several different issues. In order to clear the error, determine which issue is at hand.
New Installation The LE error code may appear in an LG washer's display if installation issues exist. It indicates a miscommunication between the wash motor and the control panel. In most cases, you can simply reset the washer to solve the problem. Unplug your washer before pressing and holding the Start/Pause button for approximately five seconds. Plug it back in and set the washer to a rinse-spin cycle to see if the code has cleared. If the code reappears in the display, contact LG at the phone number in your owner's manual for assistance.
Thermal Overload Protection Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
Excessive Suds If your washer detects excessive soap suds in the drum, the LE error code can appear. Typically, excessive sudsing occurs when you use too much high-efficiency detergent or a detergent that's not specifically high-efficiency detergent. Always follow the guidelines in your owner's manual and on the detergent label to determine what type of detergent, and how much, to use. To get rid of soap suds in the drum and clear the code, unplug your washer and let it sit for a half hour so the suds can dissolve. Plug the washing machine back in and turn it on, hitting the Spin Speed button and selecting "No Spin." Press the Start/Pause button to turn on a drain only cycle. When the cycle is completed, remove the load from the tub. Start a rinse-spin cycle to clear away any residue. You may need to repeat the cycle to remove all of the suds.
Load Issues The LE error code can appear in an LG washer's display due to certain load conditions. If you are washing a large load, don't choose a gentle cycle like Delicates, Hand Wash, Perm Press or Wool/Silk. Reserve them for smaller loads. To reset the washer, unplug it and press the Start/Pause button for five seconds before plugging it back in. The LE code can indicate that the washer has been overloaded; large loads and bulky items can strain the motor. Remove a few items from the washer to reduce the load size and restart the cycle. If the code appears again, let the washer sit for a half-hour so the motor has time to cool down before you restart the cycle.
Feb 28, 2015 | Washing Machines
Wm2277hw
Google with make, model, year for manual.
Apr 25, 2013 | LG WM227HW Front Load Stackable Washing...
I have a LG direct drive wahing machine and its flashing IE cant find manual what does it mean please help!
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. Check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. There are filters on the inlet hose connections of the washing machine. If clogged, water will not flow through these filters into the washer. Disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly. wm_inlet_filter_removal(1).jpg If this doesn't work then you will need to change the water inlet valve by removing the top panel.
Mar 15, 2011 | LG Washing Machines
What does code LE mean? The washer stops and LE appears
Code LE signals an overload to the motor. Wait 30 minutes and restart the cycle. If the code is not released, you need to call a service technician.
Jan 07, 2011 | LG WM2487H Front Load Washer
My washer wont drain and Im getting a 03 code appearing what does this mean
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Jan 06, 2011 | LG WM1814CW Front Load Washer
Error code le
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Aug 19, 2010 | LG WM227HW Front Load Stackable Washing...
My washer is blinking upside down F and E. Manual
It is actually a TE and should be the thermistor Part#
1268202
May 08, 2010 | LG WM227HW Front Load Stackable Washing...
LG CODE tcL. What does it mean?
I got the same code - I contacted LG. They have 24 hour customer service available at 800-243-0000 and my call was answered immediately. The code means "top clean load" and is not an error. You have run enough cycles and the washer is asking you to run a cycle with no clothes, and bleach only.
Apr 25, 2010 | LG WM1814CW Front Load Washer
LG washer code LE or IE showing up
LE Code continues to appear. What does this mean and how to fix problem?
Pete
Nov 18, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
124 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
