This is a common problem. The metering and light balance are the reasons that you are having problems achieving good results with your photos.
All cameras on the auto cycle are calibrated for 18% gray. Another words a photo of all white results in 18% gray. A photo of black results in 18% gray. The camera adjusts the shutter speed and aperture to achieve an average light level of 18%. That is why photos of snow always appear gray. To compensate for this characteristic of the cameras an 18 % gray panel is held in front of the camera and than the settings are set.manually. The metering in the camera is now locked and using the same light levels objects will be in their natural level.
A second problem is the white balance. Using flash avoids some of these problems. Adjusting the camera for source lighting type will help the most. The light balance is the cause of discoloration of the objects in the photo. Usually the camera white balance can be set for auto, incandescent, fluorescent, outdoor or flash,
Use a manual setting if it is available on you camera, You need to adjust the settings until you get acceptable results. If the photo is dark add light by reducing the aperture number to a lower number allowing more light. After the aperture is open wide(lowest number) increase the exposure to longer time. With very low light levels a tripod may be necessary.. After doing this once record the numbers for next time.
It seems to me that the camera is overexposing the images.
First make sure that the 'ISO' is set to a lower value such as 100 or 200. Also ensure that the Exposure Compensation (+/-) is set to '0'. For this, you might need to put the camera on 'P' mode.
Problem with the Samsung Digimax S730 Digital Camera
the camera s 730 works poperly in doors
but dosent take pictures outdoors ( after taking the picture it show a the picture as a white screen )
First the camera has a flash to allow for darker areas to be illuminated to capture pictures. The type of camera may bot allow to capture outdoor pictures with the camera flash on. Power off the flash when outdoors to capture daylight pictures.
press menu then select setup tab(wrench icon) select reset all and then try taking outdoor pics again.( resetting will not delet pictures or videos from camera.
Your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts. Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks Richard Scott Technical Support New Zealand
It sonds like teh shutter is stuck open. If the camera is indera year old it is probably still under warranty. Take it to an authorized repair shop and they will most likely repair it for free.
