My Francis Francis x1 pump is working but not pumping water. My X1 was sitting in storage for over 5 yrs and now I tried to use it for the first time in 5yrs, the pump is making noise like it used to but there is no water being pumped, how can I get it to work again?
Change the Pump, and descale the machine.
We recommend replacing with EAP5 ulka Pump.
Ulka Pump EAP5 120 Volt 52W 12000142 996530007754
Try bleading it
Testimonial: "Thanks for your response Tom and sorry for my amateurish question, what do you mean by bleeding it?"
get the hoses filled with waterie the one u want to suck fill with water then hold under water try that
ether that of valves r stuck shut
sorrie or valves r stuck in th shut pois
And exactly how would you bleed illy X9?
