Is Magnavox DVD and playstation 2 compatible to insignia tv
Tried to hook up my DVD player and playstation 2 to my new Insignia tv. Both components work fine. However, I do not get anything on the tv . Are they compatible to my tv if so how do I hook them up.
just use an rca connector, connect one end of the connector usually 3 wires for video and audio L/R.hooked up to the video/audio output jack of the dvd player and then the other end to the component input jack of the tv unit either input 1, 2 or 3.
Because it's a PS2, composite is your best bet. Plug the Yellow red and white wires into the back of the TV. Sometimes if the TV only has component inputs, the yellow output goes into the GREEN input. Hope this helps! =]
If you have the Insignia NS-42L550A11 (inputs shown here - http://www.bestbuy.com/site/olspage.jsp?id=cat13506&type=page&h=387&skuId=9595066&productId=1218131141674&navigation=prev&count=3&chk=true - or something like it), you might have a hard time plugging all of your devices into the TV.
Your DVD player might have a Component Out - if so, plug it (all 5 plugs) into the "Component" section of the TV. If you don't have a Component video cable, you can simply use a couple of Red, White, and Yellow cables instead - just be sure you connect the proper ends so the colors from the DVD match the colors to the TV.
As for your Wii and Playstation - I believe they both have the simple Red, White, and Yellow output plugs (labeled "AV IN" on the back of your Insignia). Because your TV only has 1 input for "AV IN," you might need to purchase a switch of some kind that you can plug your Wii and Playstation into and the switch will have 1 set of Red, White, and Yellow plugs to hook into the TV. The other option is to simply plug and unplug your Wii or Playstation directly to/from the TV depending on what you're playing... not an ideal scenario (particularly if you don't have easy access to the back of your TV.
The following link is for a 2-way switch that would do what you're looking to do. You could even get a 3-way switch and plug all 3 devices into it if your DVD player doesn't have a Component Out.
Generally speaking, your TV will display the signal it receives. DVD player output, for example, is 480p, but an upconvert DVD player can output the signal at 720p or 1080p. You should adjust your components (e.g. cable/satellite box, DVD/Blu-ray players, etc.) to the desired compatible output.
Use output of combo player to input of TV. Use what ever available input you have left on you TV. HDMI or Component input is best, but others will work.
if you connect composit video from your DVD player to the "Y" jack of the tv then you will get only a black and white picture .. the composit video out of your DVD has to be connected to the composit video input of the TV .. or if you have component outputs on your DVD then you can hook those up to the "three" component inputs of the tv .. (you have to have all three hooked up plus 2 audio cables ..
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Did you try using teh SV cables supplied or the RF cable?
Easier to use the AV Cables. 100% should work. Connect Video OUT of VCR ro VIDEO IN of TV and AUDIO OUT (L) and (R) of VCR to AUDIO IN (L) & (R) of TV. Select AV or VIDEO on TV using TVs remote. Play a Cassette. should work!!
