Tried to hook up my Magnavox DVD player and. Playstation 2 to my new insignia flat screen tv. Can't get anything to appear on the tv.
SOURCE: Flickering tv screen when playing playstation games.
I don't think it's a configuration problem at all. I do think that the set is not adjusting to the correct format. Most Stores have 30 day return policy. If it's over 30 days then they may not take it back. If you bought it online, then, the return may be difficult. If the return is not possible, then, contact Toshiba online and find a local Toshiba authorized servicer in your area. Hope this helps.
SOURCE: hooking up playstation 3 to a yamaha rx-v861
have you set your toybox to the appropriate settings for the TV??
SOURCE: Can't hook up playstation 2 to my Toshiba HDTV
You need to put the tv in AUX 1 or AUX 2 channel. (wherever you plugged in the game)
SOURCE: connecting playstation
good day,
i am eltoyosi and am here to help you.
the first question i will ask you is this.....does your TV set have an av-output?
if it does then make sure you plug the AV cords from the game in the following manner...........
the yellow cord is for picture display and make sure it goes into the yellow cord on your TV set.
the red and white cords are both for sounds of the left and right speakers on your TV set. try this connection and you are set to have fun with your game,
thanks.
SOURCE: Insignia flat screen (tv/dvd) combo. dvd player does not work
Get someone technical to open the unit and clean the laser lens with a swab of eyeglass cleaner and also clean the rails that the laser runs on
Please rate my help if this helps
Thanks
