My phone reads all what is on screen. touch control don't works. i have reset the phone and still starts talking everything what is on screen. i can't even answer the phone as screen don't works.
After looking for an answer, found several ones that DIDN'T worked on my phone, like tapping 3 times the power button to disable screen reader, or goto accessibility and disable screen readerAfter looking for an answer, found several ones that DIDN'T worked on my phone, like tapping 3 times the power button to disable screen reader, or goto accessibility and disable screen reader
I was able to fix the issue. very tricky, as in this mode (screen reader on) screen touch works in a limited way, that is, screen slide down to see more menu options don't works.. the easiest way would be to go to configuration, accessibility, screen reader and disable, but you will not be able to scroll down below the first 13 menu options shown in the first screen.I was able to fix the issue. very tricky, as in this mode (screen reader on) screen touch works in a limited way, that is, screen slide down to see more menu options don't works.. the easiest way would be to go to configuration, accessibility, screen reader and disable, but you will not be able to scroll down below the first 13 menu options shown in the first screen.
the way i did first was to learn howto use the screen touch again. you need to press once any button/option/char, and wait for it to be read, then press it twice, like a double click, in order the button or tchar to be typed/executed.the way i did first was to learn howto use the screen touch again. you need to press once any button/option/char, and wait for it to be read, then press it twice, like a double click, in order the button or tchar to be typed/executed.
then all i needed to do was to look for "accessibility" in the general help, to be able to acess this option directly without the need of scroll down the configuration screen, then open it, then disable screen reader which by the way is shown as BETA on my phone.then all i needed to do was to look for "accessibility" in the general help, to be able to acess this option directly without the need of scroll down the configuration screen, then open it, then disable screen reader which by the way is shown as BETA on my phone.
You can't post conmments that contain an email address.
Re: how to disable blackberry z30 z10 screen reader
Press the power button three consecutives times to activate the screen reader. Press the power button three consecutives times to de-activate the screen reader.
-when you get into your pictures (doesn't show anything i know) just see below the screen you have an option "up". When you touch it it takes you to your "sd card" from there u can select your pictures if you have in your camera folder. If not touch the "sd card" on the side left bottom and you get a pop up window with "device" option. Touch it and you will see different folders. Choose the folder where your picture is located. Once you locate the folder just tap the picture you want to attach.
For blackberry files import and export without screen, you can use blackberry link as well you can find blackberry blend services on your desktop pc and mac pc, you need to download it from official blackberry website. after download blackberry link, your blackberry mobile driver for pc already installed on your desktop or laptop, so you can easily browser from blackberry desktop application and aswell form your directly my computer page, there will show another disk as same as pendrive usb disk.
Sounds like you may have Parental Controls turned on or have disabled a feature off. Go to System Settings -> Security and Privacy -> Parental Controls and review you Application Usage settings.
