Er42 constantly slashing on my stove top, sometimes lasted for hours. When that happened you can't use the stove top until it stops. What should I do to stop the slashing?
When I switch-on "Mammoth" tape drive, the following error appears on the mammoth display " ERR: 8D 00 00". What is the problem and how to resolve ?
Thanks in advance.
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit.
To reset press the following buttons:
The code is because of bad keypad/the control panel.Have it changed.It probably non-functional and constant beeping sound is followed as you mentioned.Theres a link to explain more about this for reference.The only solution is to replace the control panel.
E7
03
Scanner position error
04
Exposure lamp blown
05
CCD calibration error
12
White level calibration error
14
Main board malfunction
15
Exposure lamp blown
L1
00
L3
00
L4
01
Main motor drive overloaded
L6
10
Polygon mirror motor not up to speed
H2
00
Fusing unit temperature error
H3
00
Overheated fusing unit
H4
00
The fusing unit doesn't heat up
U2
01
Counter error
04
EPROM error
CH blinking
Dev unit is not properly installed
I am sorry that I can not tell you exactly what that code means, Sony only releases the complete list of error codes to their employees. What I can tell you is that many error codes can be clear by reinitializing the camera’s internal software. In the Menu select Initialize.
If resetting the program does not clear the error then it’s a hardware problem. In the USA this camera has a 1 year warranty. Contact Sony repair at http://www.sony.com/service or 1-800-222-SONY (7669).
