Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Lights wont work on refrigerator side changed bulbs not the problem
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 310 Answers
The socket that holds the bulb may have a burnt wire or the door switch that operates the light may be bad.
Posted on Mar 02, 2015
4 Suggested Answers
Anonymous
SOURCE:
Anonymous
SOURCE: Lights is refrigerator side stopped working.
THE LIGHTS DO NOT WORK
Is the power supply cord unplugged?
Plug into a grounded 3 prong outlet.
TRY THIS
Is a light bulb loose in the socket?
Turn the refrigerator or freezer control to OFF. Disconnect the refrigerator from the electrical supply. Gently remove the bulb and reinsert. Then reconnect the refrigerator to the electrical supply and reset the control.
Is a light bulb burned out?
Replace with an appliance bulb of the same wattage, size, and shape. See the “Changing the Light Bulbs” section in your
Posted on May 03, 2009
danny Hendrickson
  • 2468 Answers
SOURCE: I have a whirlpool side by side refrigerator model
you need to replace the main/board for sure located in the lower rear left hand wall of the unit in a plastic case, it will have 3 wire harnesses unplug the unit,undo the plastic container and unplug the the board and there will be a burned spot on the case and burned trace on the circuit board, reason being,this is very common on any of these sideXsides,if a light blows out in the refrige compartment it puts a surge on the board and burns the circuit trace open,this makes the digital temp read-out go dark and if the lamps light at all they "strobe" dimly or not at all,and you will hear a clicking of the relays in the rear area trying to latch the light bulb circuitry, but cant because the main/mother-board is defective now
Posted on Mar 02, 2010
Anonymous
  • 56 Answers
SOURCE: Whirlpool Gold Conquest refrigerator side light
This may not be the problem now but by the sound of the malfunctioning electronics, it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Posted on Jun 10, 2010
GE Monogram ZV950S D2SS range hood - lights on one side stopped working then on both sides. This happened as I was changing bulbs. Everything else works.
Light doesn't work
  1. Light bulb
If your refrigerator light does not power on, the first thing to replace would logically be the light bulb itself.
  1. Light assembly
If your refrigerator light does not power on and you have replaced the bulb, this is an indication that the light assembly may have malfunctioned and will require replacement.
  1. Light switch
If you notice that your refrigerator lights are not working, replace your refrigerator light bulb. If this does not correct the issue, proceed to check the power light switch.
  1. Door switch
If your refrigerator light is not working and it is not the bulb itself or the power light switch, the next thing to check is the door switch. This can be checked for continuity with an ohm meter. If there is no continuity present, the door switch will need to be replaced.
  1. Light socket
If your refrigerator light is not working after replacing the light bulb, check for a possible damaged light socket. If the socket is faulty, replace the part to get your refrigerator light to power on again.
  1. Light board
If the refrigerator light is not working the light board could be defective. The LEDs on this board are not repairable, so the entire board will need to be replaced.
Feb 15, 2015 | GE Refrigerators
My rear running lights dont work even after i changed the bulbs and the fuses
Are the side markers and license bulbs working?
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Nov 26, 2012 | 1990 Honda Accord
Lights not working on the refrigerator side
If you have changed to bulbs and still no lights, you will need to replace the door switch. Here is the part you need.
Oct 21, 2012 | GE Monogram ZISS480NRSS 48" Built-In...
Lights are not working in the refridgerator. Freezer lights work. Replaced switch,still no lights
did you replace the bulb? what you can also check, and the likely cause will be the socket itself. unplug the fridge from the wall outlet, remove the bulb from the socket. you will see 2 copper tabs, on e on side, one at bottom of socket, bend these slightly toward you, to ensure they contact bulb. replace bulb, plug back in and check. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Maytag refrigerator lights won't work
the bulbs may look good but try a new one or just try tighting them into the sockets tighter. this is a common problem . the rubber prevents the bulb from going in all the way .. silcone grease on the bulb base.. mm
Dec 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
All the lights in the freezer are working. None of the lights in the refrigerator are working. All the bulbs have been changed. Is there a fuse in the refrigerator that would make the lights go out?
In your model , the refrig section light , gets its' power from the control board . When the lights stop working , so will the light for the temp adjustment display . The control board is located behind the refrig , at the bottom , on the left side , inside a white box . It is held on by 2 screws . The part costs around $ 80.00 , and is easily replaceable .
Nov 24, 2009 | Whirlpool GD5SHAX Side by Side...
Model MFS22MISBBB Refrigerator/Bottom Freezer Control Lights are not lit but otherwise the refrigerator/freezer operating normally
Have you changed out the bulbs yet? That may be all you need to do to get the lights working again. Or the switch could be out. Call us for parts. 972-859-0929. Hope this helps you! Ella
Aug 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
Lights is refrigerator side stopped working. Seems to be cooling, but no lights. Freezer light is okay. Changed out bulbs, still not working. Is there a fuse for lights?
may be the light switch or try this unplug refrigerator on screw bulb look in the socket there is a flat side in it the center get a flat screw deiver pull it up a little put back bulb plug unit if it dont light change switch
Mar 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold side by side SR2659325
are you hearing a hum then loud click hold my rating till we are done
Mar 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool side by side fridge freezer
 if posible try turning off over night, if its ok when you start it back up after 24hours, defrost not happening, ice builds up air flow is restricted
Oct 18, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
67 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
jdthefixer
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
