I can't connect to the Mobile Data, only wifi... How can I fix it??
Network authentication failed actually mean that tha settings of gprs provided by your service provider are corrupted. First ensure that u have selected your service providers gprs profile priority as default.If this is OK then Only solution is to download new settings.....for this call your service provider service no. and request it.....once new settings are received and installed the problem is solved....
Download a free app called HandyWi from the Nokia Ovi Store. This app will allow you to manage your connections in such a way that Wi-Fi is prioritised and only falls back to 3G/GPRS when Wi-Fi isn't available. This should work quite well for your email solution.
http://www.handywi.com/
SOURCE: "Packet Data Authentication Failed" what is
The error msg "packet data authentication failed" is displayed when connecting to internet via cell phone, even after having the original configuration settings provided by the supplier set to default. The problem can be solved by the following method or else contact the service provider. >Delete the old settings and then by switch off the phone. >Remove the sim card and reinsert it, after some time >gett the new settings and set it to default. Hope this helps. I had the same prblem. Even after calling cc, nothing helped. I tried all things but failed. Then unfortunately, i entered the url of the sp in the access point setting manually and wow it worked. I did this by using uninor.
Your Nokia phone will see 802.11 b/g signals. Is your home access point broadcasting one of these?
