To get to the network settings: Press the Utility/Counter key, select Administrator Settings, enter 12345678 as the password, then select network settings. You will find all the settings for networking the machine there. The print drivers can be downloaded from Konica's web site: kmbs.konicaminolta.us
User manuals can be found there as well.
Konika Minolta BizHub 163 - Error Code M2
Press the Utility button,
then Stop 0 0
then press again Stop 0 1
then scroll to Clear Data, and then Supplies Data and clear.
You must be aware that clearing this counter clears the drum, developer and other counters.
Abnormally high toner density detected Black TRC sensor-
1. Correct the TRC Connection on the underside of the imaging unit if faulty 2. Reinstall black image unit 3. Change image unit 4. Change PWB-M 5. Change PWB-MFP
you can try # 2 then run 20-30 sky shops (copies with lid up to make black copies) put a white piece of paper over lead edge section of copy glass so you are only making 1/2 black copies if you don't the copy may jam in the fuser due to excess toner. after running copies turn machine off for 10 secs to reset and power backon. if problem continues I would change the image unit.
