Yes, it is safe to leave an Igloo ice machine when it is full. However, if you plan to leave the ice in the machine for an extended period, it is recommended to transfer the ice to a freezer to prevent melting and refreezing, which can cause the ice to clump together.
Hi I had the exact same issue after about a year of running my igloo ice maker non stop. To fix it I held in the on/off button and select button at the same time for about 30 sec and TADA!! Back to making ice. If that doesn't work I've also read to leave machine unplugged for 6 hrs and then hold in on/off button for 10 seconds. Good Luck!!!!
The tray full may be triggered or stuck or another problem may exist. Look for what senses the ice being full and also check with Curtis support:
(another person was tld to do this and it workd:
1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hours.
There is some sort of arm that fits into the ice tray; when the ice fills up the tray the arm is pushed up and a switch connected to it will open the circuit and prevent any future ice maker operation(s). That switch has to be closed for unit to work!
