Your model doesn't have this feature Janome 7100QDC Computerized Sewing Machine , it it did, there would be a knob on the top left of the machine above the presser foot which you could screw up or down to increase or decrease the pressure. Its not a feature on many machines, the presser foot bar has a big spring internally which applies the pressure and this will just adjust to suit the fabric under the foot.
Testimonial: "The manual actually tells me to adjust the pressure on the presser foot to do appliqué. It does not tell me how to do this anywhere in the manual and I see absolutely no way of doing it :-("
really? that's strange. I would change to a clear presser foot with a big cut out area, my Janome 1600 has a foot like this
applique is pretty easy, just make sure you've got a tear away stabiliser on the underside to give some support and machine embroidery thread is best as it has a nice sheen when doing lots of close together stitching.
SOURCE: How to adjust the tension
You are not actually able to adjust the presser foot. For quilting you should pick up a "free motion" foot pedal made specifically for that. They run on e-bay for roughly $10-$20. Make sure you get one that fits your type of machine.
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
SOURCE: need presser foot holder
Here are the parts you need:
Brother Sewing Machine Presser Feet & Shanks
SOURCE: faulty presser foot lifter on a singer 2110/2112.
I have seen these machines with broken presser bar clamps (something inside the head). If it is just a bind then some oil on the presser bar may work, if the clamp is broken then it is probably not worth fixing.
SOURCE: MC 11000 janome stops reading presser foot "p"
This is a relatively easy adjustment as I just did one last week but I'm not sure I can explain it. Anyway, open up the lamp cover and look at the top of the presser bar. There is a sensor that is easily adjusted. It has a small phillips screw that you need to loosen. Then move the black 'L' shaped piece either up or down a little (I can't remember which way) and re-tighten the screw, you may need to experiment. The 'L' shaped piece is a flag that goes between two sensors when the foot is raised and can be rotated left and right about 10 degrees. I hope that helps.
The strange thing is, in the manual it tells me to adjust the pressure of the presser foot to do appliqu? with the blanket stitch. No where in the manual does it explain how to do this. Yup I am confused.
Thank you Carolyn :-) I searched all over the Internet for help. Lucky for me I found you!!!!
