Panasonic TH-37PE30 37 in. Plasma Television Logo
b
bILL BREWER Posted on Mar 01, 2015
Clear "invalid dvb channel message - Panasonic TH-37PE30 37 in. Plasma Television
Does the tv model sylvania tvk191 have a qam tuner?
If the TV is sold in the UK, then yes it has a QAM tuner.
All TVs have to be able to pick up Freeview to legally be sold as a TV in the UK. Freeview is the public name for the DVB-T service which is our Digital Video Broadcast - Terrestrial service. DVB-T is just the standard definition channels. DVB-T2 is the version of Freeview that includes HD as well as SD channels. The QAMs are the way in which the signal is encoded. But it's really a level of detail that you don't need to go to. It's sufficient to know that the tuner is ether DVB-T for SD only, or DVB-T2 to pick up SD and HD.
No dvb signal th-42px60b
Check all the settings.
2helpful
2answers
Does a samsung dv3 tv have freeview
Yes, it does.
DV3 is actually DVB meaning Digital Video Broadcasting. The stylised design of the DVB symbol makes it look more like DV3. If the TV has the DVB symbol, then it has a digital tuner and can receive digital channels, i.e. Freeview.
If you need assistance with tuning the Freeview channels or have further questions, please let me know the model number of the TV. This can be found on a label on the back of the TV.
Regards,
BElectric
I have a Panasonic DVD recorder with hard drive (DMR-EX769). EVERY time I switch it on the following message pops up on screen : "A new DVB channel has been found. Start DVB Auto-Setup? Selective...
I believe there is an option to stop that. It's just finding out on what menu it is on. Some Panasonic machines have it on the FUNCTION MENU then press SETUP then press DIGITAL TV TUNING. It's often listed as NEW CHANNEL MESSAGE.
Selecting that will switch it off or at least the options for it.
It's probably caused by weak stations that get detected then drop out again.
Hi I purchased a Sony 60 inch T.V model KDL60EX703U. It is supposed to have built in free view. I have set it up the same as my previous t.v however when searching for channels it does not find any. ...
When you are searching for channels check what setting the channel search is in this model had DVB-T DVB-C and DVB-T2, If it is in the wrong search mode it will not find the channels. Also does your sky decoder use a dish? if yes then this could also be the issue as the TV uses Terrestrial signals and the SKY decoder will use a Satellite System.
Will not store bbc1 dvb channel
I have contacted Panasonic, they are aware of the problem and will post you an update card to correct the fault.
1helpful
I have a Bush DVB-T set top box with no remote how do I program i
I NEED THE DRAWING OF THE CIRCUIT BOARD OF BUSH DVB DFTA 11/A
1helpful
Why do I always have the message:" A new DVB service has been found" when I switch my television on, and yet there are no new updates?
its not your TV its your free view box telling you its found more channels. DVB means 'digital video broadcast.' go into menu and select search or update channel list
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
