According to the SERVICE MANUAL, I understand that "Simulation 66-10" clears also "The confidential data". What does "The confidential data" mean? Does "The confidential data" mean the data which was stored in a FAX confidential folder?"
The MX-2310U offers Confidential Printing, which when used, requires users to enter a PIN code in order to print a queued document. To help protect your direct-print documents from unauthorized viewing, the MX-2310U offers encrypted PDF printing and scanning. Additionally, Secure Fax Release ensures received fax documents are held in memory until an authorized user enters a PIN code, so that compliance with healthcare regulations such as HIPAA is easier.
It probably will also clear the incoming folder.
66-10 is an image memory clear. It clears confidential print jobs that are waiting to be printed along with any data that's hung up in the rendering/spooling process.
Copier Collin Houston TX Copier and Imaging Expert
* Entering the simulation mode
1) #/P key (program) ON → Asterisk (*) key ON → CLEAR key ON →
Asterisk (*) key ON → Ready for input of a main code of simulation
Simply # * C * and the machine will enter simulation mode.
Then enter the number 16, which is U2 code correction, follow what the screen says, Normally just press start and the machine will reset.
U2 codes are software glitches. A U2 40 is a CRUM fault which is a drum or toner chip problem.
Sim 16 almost always clears them.
