It sounds like there may be an issue with the balance of your washer. When a washer is out of balance, it can spin violently and cause the machine to reset. Here are a few things you can try:
Make sure the washer is level: Use a spirit level to check if the washer is level. If it is not, adjust the legs until it is.
Distribute the load evenly: Make sure the load inside the washer is distributed evenly. This will help to keep the washer balanced during the spin cycle.
Check for foreign objects: Make sure there are no foreign objects in the drum or the drum's seal, which may cause the washer to vibrate.
Check the suspension: Inspect the suspension system, which supports the drum and keeps it in balance. If the suspension is damaged or worn out, it will need to be replaced.
If the problem persists, it's best to contact the manufacturer or a professional technician for further assistance.
Recently, the "LF" code has started to display and the soak cycle will not complete unless I ... Kenmore Elite Top Load Washer - Unbalanced Loads During Spin Cycly ... Would a bad outer tub literally cause the basket to become unbalanced?
? 1:21
https://www.youtube.com/watch?v=cVZIGhULzg0
Jan 17, 2014 - Uploaded by Carpe Diem
How to fix unbalanced high efficiency top load washer. ... I am having a MAJOR problem with unbalanced ...
there are struts on the bottom of the drum and springs on top. may try replacing these but I think if you level it well and make sure the feet are tightened down well it should stay quiet. it the feet are not tightened well they will vibrate and come out of adjustment
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go
through its proper motions. When the lid is closed and the washer has
filled and the agitating cycle begins, you can hear a vibrating noise
as if the plate is trying to move on the gentle cycle, but when the lid
is opened, nothing has moved at all. The drain and spin work fine, and
the machine goes through an entire cycle without error messages, but
the clothes aren't clean. You said, you have heard a lot of horror stories of how
expensive these washers are to repair, so would like an idea of what's
wrong beforehand. Here are a list of common vibration noises
Noisy, vibrating, off-balance Is the washer level? Does the washer rock when pushed against the corners? The washer must be level. The front and rear feet must be in firm contact with the floor. Check that the locknuts are tightened. See “Level the Washer.” Is the floor flexing, sagging or not level? Flooring that flexes or is uneven can contribute to noise and vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under the washer will reduce the sounds. See “Location Requirements.” Is the load balanced? Evenly distribute the load in the washer basket and make sure the height of the load does not exceed the top row of basket holes. See “Starting Your Washer.” Do you hear clicking or other noises when the cycle changes from washing to draining or spinning? When the drive system shifts or the washer basket settles between cycles you may hear noises that are different from your previous washer. These are normal washer noises. Is the washer gurgling or humming?
Is the washer level? The wash load should be balanced and not overloaded. The washer must be level. The front feet should be properly installed and the nuts tightened. Reset the rear leveling legs (if needed). See the Installation Instructions. Did you completely remove the yellow shipping strap with cotter pins? See the Installation Instructions. • Are the gears engaging after the drain and before spin, or is the upper part of agitator clicking during wash? These are normal washer noises.
Let me know if any of these are the solution! Huuum
