Sherwood RD-6500 Receiver Logo
J
John S Maurer Posted on Feb 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Find remote code for sherwood rd6500 reciever
Trying to program my XR5 xfinity remote its asking for 5 digit manufadtures code?
Audio Service Clinic
Level 3:
  • Sherwood Master 924 Answers
  • Posted on Mar 02, 2015
Sherwood Master
Level 3:
Answers
924
Questions
Helped
351427
Points
1710
The only place you will find those codes, are in the back of the owner's manual. There is usually a general procedure to find a code that works, if they don't show the make and model number in the manual.
If you don't have the manual, I'm sure it on their website.
What is the code for xfinity cable xr2 remote control?
Your XFINITY remote can be paired with XFINITY X1 TV boxes, allowing you to control the TV box even when it is placed out of sight, such as in an entertainment center or in another room (up to 50 feet away). XFINITY remotes can be identified by the model number on the back panel or within the battery compartment of the remote.
Note: Once your remote is successfully paired with a TV box, it will not control any other TV box until paired with the other TV box. XFINITY remotes can only be paired with one TV box at a time.
To Pair an XFINITY Remote Note: These instructions apply to XR2, XR5 and XR11 model remotes only.Make sure the remote batteries are installed and your TV and TV box are powered on.Set the TV input to the input connected to the TV box.Press the Setup button on your remote until the LED at the top changes from red to green.Press the xfinity button on the remote. The LED will begin flashing green. (Note: When pairing an XR2 or XR5 remote to a DTA, you may need to press the xfinity button up to five times).Follow the instructions by entering the three-digit, on-screen pairing code.
Once the on-screen pairing code is correctly entered, your remote is paired with the TV box. Note: If you do not see on-screen pairing instructions after pressing the xfinity button in step four, press the xfinity button again. You may need to press the xfinity button multiple times if there is more than one TV box in range.
how4474_072816_01-kmuj4sm5av3gyijxunj5wf5e-1-0.png NOTE THE BELOW CODES ARE FOR THE SAMSUNG SMART TV's ONLY
Type in the 4-digit or 5-digit code listed below using the number buttons. Additional codes may be found in the remote manual.
Most likely code
10812
Others to try
11632, 10702, 10060, 11959, 10766, 11903, 11060, 10587, 10329, 10482, 10650, 10814, 10032, 10178, 10030, 10019, 11575, 11597, 10427, 10408, 10217, 10056, 11581 for more info on what device you are trying to pair it with the codes are available here > https://www.xfinity.com/support/remotes/ Just select the Remote and the device and continue and the page will display the most common codes for that Device you are trying to pair it with.
I have a rca tv an a xfinity xr5 remote the I need a code for to program
0270,0231,0274. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
1helpful
How do I program a comcast xfinity remote for a Dynex tv
Hello there
From this page, http://customer.comcast.com/remotes/
I used the first type of remote and I got
  1. Turn on the TV you are programming.
  2. Press and release the "TV" button on your Universal remote.
  3. Press and hold the "Setup" button on your remote until the button blinks twice.
  4. Type in the 5-digit code using the number buttons. Most likely code
    11463 Others to try
  5. If the code is correct, you will get 2 blinks. If the code is incorrect, you will get one long blink.
  6. Use the Universal remote to operate your TV (use Power, VOL, etc..)
  7. If these steps don't work, look for another code and repeat the above.
2answers
Xfinity remote setup
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
LG 55LH90 TV to Sherwood RD6500 receiver
That's what manuals are for.
Video Out on the receiver goes to Video In on the TV. That's all you really need.
I recmmend you grab any TV-related audio from wherever its source is for the highest fidelity sound (NOT the TV).
1helpful
Sherwood 6500 reciver
check your speaker wires make sure they are not shorting against each other down the line, that will cause the reciever to go into standby.
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Ngoro
Arnie Burke
Arnie Burke
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
