The washer has been making loud noises when during non-spin parts of the cycle, and then stopping with the error codes 4E and today 3E showing respectively.
SOURCE: maytag washer 3e fault code
3E == overcurrent detected at the motor.
Open the control panel, there you will find a tech sheet that explains how to put the machine into service mode and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes. You will also find serveral other diagnostic service notes. Read them and follow the instructions to test the motor, motor control, and main control board.
SOURCE: loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
SOURCE: Maytag front loading washing machine
This worked for me for the E3 error code: Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
SOURCE: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
SOURCE: cycle stops 3E code appears
Well the error code 3E means that the overcurrent is detected at the moter.
Please check it if you have some overcurrent problem!
Thanks!
mannu_rakesh
