After attempting to hook up a blu-ray player to my 37 in Vizio, the screen is blue and reads 'no signal'. HDMI1 port works fine and the blu-ray worked on that one but HDMI2 is not. How do i fix this issue? I've tried unplugging all devices and resetting the system but i'm still getting the same blank screen. I've even purchased a new HDMI cable and that didn't work either.
SOURCE: Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
SOURCE: Purchased and set up both Vizio SV370XVT HDTV and
Try setting your cable box for Closed Captioning. Worked for me.
SOURCE: hdmi not working
Probably a bad port, but if you can get the TV near a PC or network connection, I highly recommend Vizio's customer service. They will be able to test for exactly what is wrong, and possibly even push out a software fix to repair it. If it cant be fixed with software,, they will get a certified tech out to handle it for you.
SOURCE: Our 42" Vizio will not display/play sounds when
Hello
One board takes in the HDMI as well as the other signals. Sometimes part of the board breaks and that is what sounds like has happend in your case. This is a fairly common problem and most people tend to just live with it. Others sell thier tv and a few find the number of thier board to see if one is available on ebay or shopjimmy. If you are comfortable with electronics the board is not hard to replace.
Im sorry your HDMI broke....
I hope this helps
