SOURCE: discolored white nautica watch band
If your watch band have UV sensitive pigmentation in it, there is nothing you can do, but buy the new band.
Find your nearest jeweller and ask to clean watch band in ultrasonic cleaner for 1 hour. If this kind of cleaning doesn't help, that means your watch band is UV sensitive and is and will be discolouring more and more by the time.
Alternatively you can try to clean it with the lighter fluid (ZIPPO). Soak a soft cloth in to lighter fluid and clean the band. Start with a small area inside band to make sure the fluid is not reacting as dissolver, as some resins react quite vigorously and tend to transform into chewing gum sort of state.
And again- if this cleaning doesn't help, the band is UV sensitive and discolouring is taking place.
That discolouring is happening becouse some of the colour pigments used in resin manufacture are sensitive to ultraviolet light and when exposed to sunlight or daylight, they react in a chemical
way, changing molecular structure, wich we see as the colour change.This process can not be reversed and this is why the band can not be cleaned.
Do not forget to rate please.
SOURCE: Where can I buy a new White Resin Nautica watch band.
If you go to the web site www.nauticawatches.com and select "service center" you will be able to see all the service centers. Choose your nearest and ask them.
Testimonial: "THANK YOU"
SOURCE: replacement band for my nautica watch N17524G
Follow this link and contact Nautica: http://www.nautica.com/helpdesk/index.jsp?display=store&subdisplay=contact Rate me plz.
Testimonial: "excellent work ! thanks a lot !"
SOURCE: I NEED TO SET THE DATE AND TIME ON MY
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please
