Tablets & eReaders Logo
j
jady anderson Posted on Feb 27, 2015
How can I get a flash player on my nextbook
I have downloaded flash player but it won't install or work
Update flash player on my Nextbook are 11a
Any updates would be at the website of the company whom makes the software.
How can I download flash player ?
Tap "Install" on the next screen to confirm. When Flash is installed, head into your phone's stock browser (again, Google Chrome won't support your newly-installed Flash apk). On Android 3.0 or later, go to Menu (three dots next to the address bar on some phones) > Settings > Advanced > Enable plug-ins.
How to set memory card as default memory storage
Download Titanium back up. it has all you need you can move all the apps to sd card including built in apps (the ones that can not be unistalled)
Caution: your phone has to be rooted juts google how it can be done in case you are not rooted yet. and be carefull while moving apps some apps can cause damage to your phone if moved to sd card. just move the downloaded ones and some few like photo viewer, galary, music player and the like
How to unlock apps on nextbook
1. Back up everything you feel is important before you start.
2. Charge your device to 75% or more before you begin to prevent unwanted shutdowns.
3. This method will only work for the versions of Nextbook 8 bought before August 2013. Check the back of the tablet and if the serial number begins with YFG1013, YFG1113 or higher, this procedure is not for you!
II. Necessary Downloads
1. SMT_Next8HD8G_Mod_Recovery.zip [Download link available in this post]
2. Kyser_Root-signed.zip [Download link available in this post]
III. Rooting the Nextbook 8
1. Extract SMT_Next8HD8G_Mod_Recovery.zip to a folder on your desktop. You should end up with a file calleduImage_recovery with no extension.
2. Connect your device to your PC and copy both uImage_recovery and Kyser_Root-signed.zip to your device's external SD card (not the internal memory, insert a microSD card if you don't already have one); do not put them into any subfolders just drop them in the main folder of your device's external SD card.
3. Power down your device and reboot to the modified recovery you have just copied. To do this, with the device powered off, press and hold the Volume Up + Volume Down buttons with the Power button until you pass the splash screen, a black screen and you see the recovery menu.
4. Use the Volume Up and Down buttons to highlight the 'Flash zip from EXT card' option and the power button to confirm the selection.
5. Once flashed, go back to the main menu and select 'reboot system.'
Once the Nextbook 8 reboots, check for the SuperSU app in the app drawer (install it from the Play Store if you don't find it) to verify you are rooted!
How do I find my library book on my next book
I am assuming you downloaded an audio book (an MP3 file), in which case you have to open any media/audio player app that you have installed on your Nextbook and it will find that file for you.
Top Nextbook Tablets & eReaders Experts
NOEL
NOEL
john h
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
