Computers & Internet Logo
A
Anonymous Posted on Feb 27, 2015
How do I unlock a text?
When I click on a text to open it. it comes up on my scrfeen as a "locked" item.
Vitally Alcher
Level 3:
  • Dell Master 1,645 Answers
  • Posted on Feb 27, 2015
Vitally Alcher
Dell Master
Level 3:
Answers
1645
Questions
Helped
467352
Points
3209
How do i unlock javascript
You can unlock most items by highlighting item going into finder bar and selecting get info, clicking on that and it will tell you if item is locked and who can see or change item. You might need your password to change the locking or unlocking.
How to change view size in windows 8
You can change the view size in Windows 8 in the following ways:
1) By changing the size of text and other items on the desktop
You can change the size of text and other items (like icons) on your desktop without disturbing your current screen resolution settings. To do this, follow the steps mentioned ahead:a)Open Screen Resolution by swiping in from the right edge of the screen, tapping "Search" (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking "Search"), enter "Make text larger" in the search box, and then tapping or clicking "Make text and other items larger or smaller".
b) Drag the slider until the items in the preview image are the size you want them to be.
c) Tap or click "Apply".
You'll see the change the next time you sign in to Windows.
Also, you can change the text size for specific items (such as Window title bars or tooltips) without affecting the size of anything else on your desktop. Follow these steps to do this:
a) Open Screen Resolution by swiping in from the right edge of the screen, tapping "Search" (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking "Search"), entering "Make text larger" in the search box, and then tapping or clicking "Make text and other items larger or smaller".
b) Under "Change only the text size", choose the item you'd like to change and pick a text size. If you want the text to be bold, select the "Bold" check box.
Note: To view a pictorial description of the above process, refer to the link:
http://nvidia.custhelp.com/app/answers/detail/a_id/3153/~/adjusting-windows-8-display-size%2Fscaling-for-high-dpi%2Fppi-monitors
2) By changing screen resolution
You can change the view size on your desktop by changing screen resolution settings. To do this, follow these steps:
a) Swipe in from the right edge of the screen, tap "Settings", and then tap "Change PC settings" (If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, click "Settings", and then click "Change PC settings").
b) Tap or click "PC and devices", then tap or click "Display".
c)Tap or click the resolution slider and drag it until you find your desired resolution.
d) Tap or click "Apply".
To know more about the best screen resolution settings for your desktop, refer to "Set your monitor to its native resolution" section on the following link:
http://windows.microsoft.com/en-IN/windows-8/get-best-display-monitor
GuruAid.com
How do i make the type larger i can hardly read it
If you have Windows 7 or Vista you can do this:
  1. Open Screen Resolution by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
  2. Choose one of the following:
    • Smaller - 100% (default). This keeps text and other items at normal size.
    • Medium - 125%. This sets text and other items to 125% of normal size.
    • Larger - 150%. This sets text and other items to 150% of normal size. This option appears only if your monitor supports a resolution of at least 1200 x 900 pixels.
  3. Click Apply.
Micron transport
follow this steps and fix it. God bless you
· Log on to your PC computer with an administrator account.
  • 2
Open the "Start" menu and click on the "Run" button.
  • 3
Type "keymgr.dll" into the text box and hit "Enter." The Key Manager utility program will launch and display a list of passwords used on the computer.
  • 4
Highlight the password item you want more information about.
  • 5
Click on the "Properties" button on the right side of the window to view more information about the selected password item. The pop-up window will display the username, password and server address for the selected item.
How do I remove the background colour from desktop icons
Just click right on the desktop ..and select desktop , than select on the down page the customize desktop and select web (the one in the right ) ..
If you see a web page checked in the tab .. remove it ..and the important thing ..remove the check mark for the lock desktop items cause this is the one responsible for that color present under the icons..and click apply ..and OK ..restart and repeat the action if it seam not willing to do that ..or select windows XP theme again ..and this way probably will default it ..but the way to remove it to unlock the desktop items ..
The letters are to small and pictures too,i need to zoomout alittle bit..
This solution is for windows 7
To make the text on your screen larger or smaller
Open Screen Resolution by clicking the the Start button, clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
Click Apply.
To see the change, close all of your programs and then log off of Windows. This change will take effect the next time you log on.
How to change icon size
1. Click the Start and then choose the Control Panel option.
2. Control Panel window opens up. Click Display. 3. Choose one of the following:
Smaller - 100%. This keeps text and other items at normal size.
4. Click Adjust Resolution in the left pane, window opens up as below. 5. Click Set custom size text (DPI) in the left pane to customize the text size.
Drag the ruler with your mouse to increase or decrease the percentage.
Click Ok.
Click Apply in the main Display Window. click Log off now to save changes.
6helpful
4answers
How to change text size to be larger
This depends upon what program you are running.
If you mean the Internet, you can change the view settings on most browsers by zooming in (go to "View" in your toolbar).
If it's a Microsoft application like "Word" or "Excel", you can increase the font size or the magnification of the document - again, from the toolbar.
1helpful
Maps not found
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
If the maps are locked you'll need a garmin account. If you don't have one already go to www.garmin.com Click on my garmin and then on register your garmin device. Note you'll have to create a username and password. Write them down and keep them safe. You'll need them anytime you update your satnav.
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Creating an unlock code file for Mac:
  1. Open the TextEdit application located in the Applications folder on the Mac HD
  2. Click Format
  3. Select Make Plain Text
  4. Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  5. Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  6. Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
  4. Click Explore
  11. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  15. Type gmapprom1.unl in all lower-case letters for the File name
  16. Select Save
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Troubleshooting
get hold of your nework operator and ask for a sim update, this will solve the problem
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
