3 wires out of the controler too car wiring
SOURCE: xbox 360 controller one wireless two wired
The port on the XBox has gone bad or there is dirt or something in the port. Use compressed air to blow out the port and see if it helps. If not the unit needs repair.,, try this out and see...
thank u rate me
SOURCE: should i conect the dimmer wire to the positive or
The dimmer will usually be positive. If you are in America. Some places have a Positive Ground.
The dimmer wire should connect to the positive.
The only difference it will make is that the display will not light up, or it will with the dash lights.
There's no risk with that. Just be shure you have the right wire.
Test it on a permanent positive if neither side of the dimmer swithch works.
SOURCE: wireing turner plus 3 to president washington that is four pin
Wow I've never seen a six wire Turner + 3 anyway give this a try 1)shield & blue 2) white 3) black 4) red if the radio keys up as soon as you plug in the mic switch black and red . Good luck . Dan
SOURCE: Conect 4 wires to 3 wires box in the wall
Wonderful help to me ! Here I am on this website trying to help others, and just by accident I find your writeup to help my own problem. Yesterday I got a new dryer with the new 4-prong plug. I didn't know the electrical code changed since my 1987 dryer was installed (hardwired).
Thanks for the clarification !
SOURCE: i want to wire a 3 phase planer up. I have three
install 30 amps 3phase breaker, then wire it up with royal cable 5.5mm x 4wires
