Camera batteries do not last the lifetime of the camera. Its lifetime depends on usage and the number of times it's been charged. You may simply just need a new battery
Here's a guide;
What do the battery lights mean on my mouse?
Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model
Status
Single long green blink
Rechargeable
Batteries are good. This occurs when batteries are first installed or every time that the device is turned on.
Slow green blink
Rechargeable
Device is docked in the charging station and is charging properly.
Steady green
Rechargeable
Device is docked in the charging station and does not need additional charging.
Steady green
Presenter Mouse (Japanese version)
Laser pointer is on.
Red/green blink
Wireless
Device is discoverable (trying to connect to the transceiver).
Slow red blink
Non-rechargeable
Batteries are low and need to be replaced.
Slow red blink
Rechargeable
Batteries are low and need recharging.
Fast red blink
Rechargeable
Device is docked in the charging station, but there is a charging error. Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad. Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them.
Steady red
Presenter Mouse (Standard version)
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In ______________________________________________________________________ •Headset Indicator Headset Status Red-----------------------------------------------Charging (battery level less than 50% charge) Yellow-------------------------------------------Charging (battery level more than 50% charge) Green--------------------------------------------Charging complete
---------------------------------------------------------------------- ====================================================================== ====================================================================== ====================================================================== ---------------------------------------------------------------------- With No Charger Plugged In __________________________
Headset Indicator Headset Status ______________________________________________________________________ Off ---------------------------------------------Power off Three blue flashes------------------------Powering on/off Steady blue --------------------------------Pairing/connect mode Rapid blue/purple flashes -------------Connection successful Quick blue flash --------------------------Incoming/outgoing call Slow blue pulse --------------------------Connected (on a call) Slow blue flash ---------------------------Standby (not on a call) Slow red flash ----------------------------Idle (not connected to phone) Slow purple pulse -----------------------Connected call muted Steady red ---------------------------------Attempting to connect Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on ----------------------------------------------------------------------
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Charger flashing red indicates the battery is still not full and is in the process of recharging. Red light steady indicates your battery is fully charged and ready to operate with your Coolpix 5000. When red light is off it indicates there is no battery inserted or the charger is not pluged in.
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Hi there. Sounds like the battery could be faulty. The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery If an AC adapter is not connected to your computer, the computer's power source is a battery. If the battery indicator flashes amber or is a steady amber, the battery needs to be charged. If the battery is flashing green and amber, the battery may be defective. To troubleshoot this problem, use the following procedure. 1. Turn off the computer and peripherals, and disconnect them from AC power. 2. Reseat each installed battery by removing it and then replacing it. 3. Turn on the computer. Does the green power indicator light up? Allow one minute for the computer to initialize its components before checking for signs of power. Yes. Continue to step 4. No. Use the AC adapter to connect your computer to AC power. If the computer operates normally when using AC power, go to step 7. If the computer does not boot when using the AC adapter, see the previous subsection, "Total Power Failure When Using the AC Adapter." 4. Does the battery indicator flash amber or show a a steady amber light? Yes. The battery needs to be charged. Go step 5. No. Go to step 7. 5. Connect the computer to AC power, and fully charge the battery. For instructions, see the topic titled "Charging the Battery" in the online System User's Guide. 6. As the battery charges, does the green battery indicator light up? Yes. Go to step 9. No. Go to step 7. 7. Is the battery indicator flashing green and amber? Yes. Your computer may be in a hot environment. Charging the battery in this condition may affect the life span of the battery. Continue to step 8. No. The problem is resolved. 8. Disconnect the computer from AC power. Is the the battery indicator still flashing amber? Yes. You may have a defective battery. Continue to step 9. No. The problem is resolved. 9. Remove the battery, and press its test button. Is the uppermost indicator in the charge gauge of the battery flashing? Yes. You have a defective battery. Continue to step 9. No. The problem is resolved. 10. If a spare battery is available, fully charge it, and then install it in the computer. 11. Turn on the computer. Is the power indicator off? Yes. Your original battery is defective.
Rub the terminals of the battery with your fingers and than again put it on charging .... before doing that remove the battery from the cell for an hour..
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
