How to use recorder to record
SOURCE: dvd/vcr recorder stops recording
DVD-RAM itself, and DVD-R formatted in "VR" mode are SUPPOSED to allow for recording "ONE TIME" per DRMA. The broadcasters are probably sending the wrong copy protection signal if the -RAM & -R/VRmode are stopping.
At least, that is my understanding.
tom
SOURCE: Need code for Viore TV to program LG RC897T DVD/VHS Recorder
I believe Viore is the same as Samsung. I only noticed this by accident as I bought a Viore TV and my friend bought a Samsung and I noticed both remotes were identical. I tried the Samsung codes and the remote worked. Good luck! Kevin
SOURCE: LG RH266 setup with freeview tv
Sorry to say no it wont not unless the Tv set manuel says it has a Duel Freeview feed , you have to get another freeview box for the recorder .
besides If you used the freview in the tv 1 , the tv would have to be on when you wanted to record ?. and 2 you couldnt watch another channel whilst recording another .. only 1 tuner ?. also you could only record the program you had on .at the time no timer facility .
People are still used to the Old system of VHs and the fact that all videos had tuners built in so you could watch and record .. It will come and indeed some more modern DVD recorder have freeview built in again sorry but thats the facts , and dont forget if you want the pay per view channels on free view your going to need a tuner with a pay card port ... Regards Vortash
SOURCE: LG RH399H
I have the same problem with the same model LG, bought a year ago. It only gives the 'Record-blocking signals detected' message when there's something I really want to record. Over the winter it was Jane Austin's Pride and Prejudice. Today it is the British Open Golf from Turnberry. We are out tomorrow, for the last day of play and can't record!!!!! It seems this player has build in blocking signals even to channels we can normally watch. Any help would be appreciated - before tomorrow, July 19th.
SOURCE: Stop Substitles on a LG RHT497H 160G dvd recorder?
I have the LG DVD recorder DRT389H which has the same problem. You can't switch off the subtitles during timer recording from the Electronic Programme Guide. The only way I could stop this was to go to the main set-up menu then select the A icon. Select DTV Subtitle and choose a language that the TV programme isn't broadcast in. I chose Gaelic. The only disadvantage is that this stops any subtitles being recorded so you can't access them later.
