Televison & Video Logo
r
robertgedwards Posted on Feb 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just bought a !9" digital flat screen Apex. Hooked it to an indoor HDTV antenna. All I can get is "NO SIGNAL". What do I try next?? Bob E, Technical Dunce over 80.
Dan Theman
Level 2:
New Friend:
  • Expert 49 Answers
  • Posted on Feb 26, 2015
 Dan Theman
Expert
Level 2:
New Friend:
Answers
49
Questions
0
Helped
7942
Points
340
Bob, If you have an hd ready tv, and hooked up the Ant. then the next thing you should do is go to your menu and select the tv feature and then scan for channels. This should program the channels for you. Most TV setups are like this. You should have a option for cable or antenna/tv input. select Antenna. You r should be good to go once the channel scan is done.
Hope that helps
Dan
2helpful
2answers
How do I hook an antenna to my tv
Hi Dwayne,
The Proton has an NTSC analog tuner and also an ATSC digital tuner. Have you tried switching or changing the SOURCE inputs?
You may also have to use the scan button to have the tuner "find" the channels for you once you determine that you have selected the correct source for the antenna.
See page 9 of the manual.
http://www.manualslib.com/manual/323457/Protron-Pltv-4250.html?page=17#manual
1helpful
I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
Terk od amplified indoor digital antenna installed after install of wintv-hvr 1600 internal hdtv card. win7 opens, followed instructions to scan for atsc digital tv.....NO CHANNELS FOUND. cables...
Unless you are very close to the TV transmitter aerial it is very unlikely that you will get adequate signal for digital TV with an indoor antenna. Check with your neighbours to see what they use and where the nearest transmitter is.
Unfortunately, with indoor an antenna, the amplifier also amplifies any electrical interference from other devices in the building.
First step would be to try taking it outdoors (use an extension cord to get well away from any buildings, trees or large metal objects that could block the signal).
Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
I bought a Proscan 26LB30Q TV. After connecting to the indoor digital antenna, no signal showed up on the screen. What could be wrong? Thanks.
MAKE SURE WHERE YOU HOOKED UP THE ANTENNA SAYS DIGITAL,,IF ITS NOT IT WANT WORK ON TOUR TV,, POEPLE THINK JUST CAUSE ITS A NEW FLAT SCREEN THAT IT DIGITAL,,, BUT A LOT OF THEM STILL ARE JUST ANALOG ANTENNA READY,,,,,THE ANTENNA JACK SHUOLD SAY EITHER ANALOG OR DIGITAL,,
5helpful
I have a Westinghouse 26 inch TV. Model # SK-26H590D. It will not scan channel 9. I have tried both the automatic scan and the find channel scan. It is hooked to a Phillips Mant 510 vhf/uhf indoor antenna...
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
2answers
IS MY TV DIGITAL?
yes you will. either install an outside antenna or get a good amplified indoor antenna. try your old antenna first, but when your picture freezes or it says something like " weak signal " you will need that new antenna
3answers
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
