You may have a virus or an update that didn't install
You did not say which OS you are using so here is the answer using Windows 7
Remove any DVDs or USB storage devices from your computer, then restart the computer.
When you start the machine, continually keep tapping the "F8" key until the logo disappears. The Advanced Boot Options screen appears.
Press the down arrow until you have highlighted the "Safe Mode" item. Press the "Enter" key to boot Windows into safe mode.
Open Search box. In the search box, type System Restore, and then, in the list of results, click System Restore.
Follow the steps in the wizard to choose a restore point and restore your computer.
SOURCE: Intel E210882 Motherboard Manual
I'm looking for the same manual. The link isn't for the right manual though it's everywhere I look. My E210882 ISN'T a micro atx and it has 4 dimm slots.
SOURCE: motherboard manials
http://downloadmirror.intel.com/15206/eng/D865GBF_D865GLC_ProductGuide02_English.pdf You can download the manual from the link provided above.. good luck...
SOURCE: Good Afternoon Sir.!!
Intel has an auto detect and download drivers tool here: http://www.intel.com/p/en_US/support/detect/ which you could try.
If that doesn't work you can also follow the intructions here http://devid.info/en/page/device/
It should hopefully give you a driver for your device.
Thanks
SOURCE: vga driver Intel Desktop Board D865GBF
Here is a link to your boards download page. CLICK HERE. Select your operating system from the drop down menu on left, and then select driver downloads from the menu on the right.
SOURCE: sound driver of intel E210882 motherboard
Hi rukan
intel e210882 motherboard drivers can be found at
driverupdate us .
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
