Question about Thomson Televison & Video
How do I access the menu on my Thomson 100hz high focus t.v (it's an older style) without the remote?
6ya staff
SOURCE:
Anonymous
  • 206 Answers
SOURCE: Magnavox TV accessing menu without remote
There may be away but need the model number to narrow it down, most remotes can be found at www.vancebaldwin.com and for usaly under $20.00
Posted on Feb 13, 2008
bhiga
Brandon Higa
  • 119 Answers
SOURCE: Phillips 25 HT Television
If you have a Pronto you can get codes from Remote Central otherwise you might want to look for a higher-end universal remote that may have the Setup keys you're looking for.
There are also several JP-1 remotes out there that allow programming codes like Pronto, but not as simple.
Posted on Apr 05, 2008
jimorjenn
SOURCE: No Remote - Need to access Menu
We had the same problem - this worked for us:
1. Unplug TV
2. Press Channel up and Volume up at same time, while plugging TV back in (two person job - it will pull up a service screen)
3. Press Channel up and Chanel down at same time. (Access to menu screen)
4. Use Volume up and Volume down to switch between menu options. We finally found the EZ set up screen.
Somehow in the process we muted the TV and are now working on getting the sound back. :)
Good luck to you!
Posted on Oct 05, 2008
Anonymous
SOURCE: Accessing Menu Sharp TV
I have a Sharp TV model 27F-S40 and also do not have the remote. I need to access the menu to change color, sound, etc.
Can I access the menu thru the channel or volume buttons on the face of the tv?
Bob
Posted on Nov 08, 2008
Anonymous
  • 7 Answers
SOURCE: acessing menu without remote
A) Look for a menu button somewhere on the tv itself .. Usually volume or channel buttons serve as up and down, etc..
OR
B) Go to electronics store and buy a universal remote $10-$20 and program it for your tv.
Posted on Aug 15, 2009
Hi i need to cancel boost mode on my Thomson cs806. but i don't have a remote controle, can any one know how to do this ? thanks
Without remote control; you can't. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Jan 27, 2015 | Thomson Televison & Video
TV Thomson Scenium 28WF64E L
See that any of the buttons are pressed or any thing is shorting any of the switches or wires or PCB in your Television
Mar 15, 2008 | Thomson 28VK25US TV
How to access tv menu from tv without using remote ?
You should have its remote control to access its menu options. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 21, 2014 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Sanyo tv menu access
Without its remote control, you can't access its service mode option. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 07, 2013 | Televison & Video
I need to access the service menu without the remote
You can't enter its service mode, without a remote control. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 03, 2013 | Samsung LN37A450 LCD TV
Thomson tv repair
Flashing red indicates internal shutdown due to fault protection.
Only a tech can diagnose the fault (and hopefully repair it).
Good luck with getting it done quickly. :)
Clive.
Oct 06, 2017 | Thomson Televison & Video
THOMSON TV V21DU22VT REMOTE
To know more about it, you have to contact the authorized service center. If you need a universal remote control, and if you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and proceedings to some popular model remote control are given. Check it out and see which remote control have setup codes with Thomson brand TVs. Buy one according to availability.
Mar 03, 2013 | Televison & Video
I have lost my remote control for my Thomson Tv model number 28WR25UG and is stuck on set up language page, how do I get rid of this without a remote?
Without a remote control, you can't change this option. Just buy one universal remote control, which have setup codes for Thomson Brand.
Jun 17, 2012 | Thomson ROC3205 Remote Control
Programing TV THOMSON 29DM 400 Type 556/ETC 210 without remotecontrol
you can get a cheap universal remote for about 5 bucks. But if your tv doesnt have a menu button on the set itself then some tvs you have to push either the volume buttons up and down at the same time and the menu should pop up. or it could be the channel buttons
Nov 23, 2010 | Thomson 29DM400 29" TV
Televison & Video Logo
108 people viewed this question
Top Thomson Televison & Video Experts
Todd Hill
Todd Hill
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
