Question about Kodak EASYSHARE Z1285 Digital Camera
My camera won't turn on. the screen flashes, but nothing happens. it turns right back off. the lens is pushed all the way out like its zoomed, but its obviously not since i cant so anything with it. batteries are fully charged. whats wrong?
    Problem Solver:
  • 5 Answers
I would try a new set of batteries.. It sounds like maybe the batteries you are using are not charging correctly or that the cell has well... died.. so try a new set of batteries and if that doesn't fix the problem I would (if you have electronic experience) take out the screws and see if there are any loose components inside that are making it so the camera isn't operational
Posted on Jul 10, 2009
    Problem Solver:
  • 11 Answers
I do not recomend taking the camera apart. But I do agree with replacing the batteries!
Anonymous
SOURCE:
Won't charge
You have a Dead Kodak !!! needs to go to shop.
Sep 24, 2012 | Kodak EasyShare M532 Digital Camera
DSC-HX5, Lens is Stuck in Zoom out mode. Turn On works but screen stays black. Automatically turns off after 10-20 seconds.
Since there is nothing you can do to fix this at home you have 2 choices, replace the camera or send it back to the manufacturer for exchange (very expensive)
Jul 27, 2017 | Sony Cyber-Shot DSCHX5 Digital Camera
I turn my dmc-fh27 camera and the lens won't come out. it is trying to move but it will not budge and the screen says "System Error (Zoom)".
Warning: This is only a last resort if you no longer have a warranty.
I used a variety of different methods, but here's what worked for my camera. Apparently the lens was just off the track.
1. Turn on the camera, and smack the back against the palm of your hand to get the lens to come out.
2.Hold the lens out until the "error screen" comes up.
3. Take the camera with the lens facing towards you, and use your thumbs to push on the lens.
4. Push firmly until the lens "clicks".
5. Turn off camera, then on again.
6. Hopefully cry tears of joy that you fixed it.
Jun 12, 2011 | Panasonic Lumix DMC-LZ2 Digital Camera
Camera says turn off and turn on panasonic lumix dmc-fs5
While you are turning the camera on, hold the lever which you use for zooming in. The lens should extend before you get the annoying message about turning the the camera off and on. Then, gently apply pressure to the lens as if you wanted to push it back to the camera. While you are doing this, turn the camera off (lens should come back into the body of the camera). This will solve your problem.
Thank you!
May 17, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
My flash isn't working anymore!! (fz50)
Find the setting for "conversion lens" in the menu, or tools menu.
Turn it off.
Turning the "conversion lens" on blocks all flash function.
The conversion lens is a extra lens that you can purchase to screw onto the front of the main camera lens for extra zoom or wide shots but it blocks the flash, so your only meant to turn it on when you have one fitted.
Sep 25, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
Will not focus
First Send me your camera's model (Brand Name)
Some digital and analog camera in these days has features to manualy set the focus in our wish.
Try to disable this feature. And try not to poke or push the lens of the camera. By doing this you may destroy the lens.
And try to reformet the mem stick + try to reset the camera.
(Everything will be resetted, "it will be as if you have a new camera")
Feb 03, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
Lights are on but nobody's home!
I had the same problem two years ago and because the camera was still within warranty coverage, I was able to return it to Olympus for no charge repair and they fixed the zoom lens gear and it works fine.
Oct 14, 2007 | Olympus SP-320 Digital Camera
Not focusing
Do you hear any unusual friction noise while the lens assembly projects out.. if so then the traction assembly of your zoom barrel has developed mechanical obstruction, in which case it has to be serviced. Take it to the service centre and the problem will be solved. If the zoom assembly does not fully extent to its homing position, the camera retracts and lens and powers itself off. Enjoy
Aug 16, 2007 | Olympus FE-230 Digital Camera
Kodak EASYSHARE Z1285 Digital Camera Logo
137 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
