Look at the middle cover (above the keyboard). there are two buttons that touch the power switch, the one to the left enables/disables the touchpad. If it shows an orange light it is disabled. Just press it, and be careful not to hit it when turning unit on.
thank you so much it really worked for me.
Tawazzile
You are great, it worked perfectly well, thanks a million times
perfect - simple but effective solution ......thanks!!
Worked like a friggin charm. Thanks AcerTech!!!
that was great. it is fixed. thank you so much!!!!!!!!!!!!!!
This is dumb. I'm a tech and I couldn't figure out why it wasn't working in Windows, but it worked in DOS. Then you suggested this and it worked! Why it disables itself by default is beyond me. Thanks!
Plug a USB mouse into any USB port and use this mouse to go into control panel or mouse utility to configure mouse pad, or just use the USB mouse. Check device manager for any error icons.
Sometimes takes a couple of minutes for USB mouse to be recognized.
Hi please help, can i turn the scrolling bar off on the tiuch pad on E525
There is a phone number for tech support in america. it is out of temple,texas it is called emachine usa and the phone no is 254 298 4000
touchpad not work
