Olympia InfoGlobe Caller ID Logo
K
Kathleen Cotton Posted on Feb 25, 2015
I have had my globe for over 10 years and the text is starting to read wrong. Is there anything I can do about this or is it time to get a new one?
We have 5 Nissan NP200 bakkies. It keeps blowing the headlight globes. Cant find anything wrong. What else can we look at?
Check the quality off the globe ,,2 check if the globe is getting an moisture and stop that , 3 Check your charging rate 13,44 --- 14.08 4 check is all connections to globes is secure i.e all switches all relays all plugs
Unable to read mode. It remains in recording mode whatever mode I select.
After years of use these wear out just like anything else, if the camera is 10 years old it is going to cost you more to have it repaired than it will cost to replace it. 10 years is a long time, and the price for repairs will be sky high.
How to activate my mms? globe prepaid
  • For a complete listing of compatible MMS & GPRS phone handsets — send Nokia, Ericsson or Samsung (your handset model) to 2365.
  • To get your phone’s settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, refer to #1) Note: For Nokia 6220, 6600, and 6820, text GO < handset model >,1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN. Regular text messaging charges will apply.
  • Enter 1234 when asked for PIN to save settings.
  • Send an MMS message for only Php 5.00 to activate the service.
or
This tutorial will help you setup your mobile phone and activate/configure GPRS, 3G and MMS features for Globe Telecoms.
GPRS SETTINGS
1. Go to Menu > Choose Settings > Connectivity
2. Go to Data Accounts
3. Create New Account. GPRS/ PS Data
Account Name: MyGlobe GPRS
APN: www.globe.com.ph
4. Save Account
5. Go to Internet Settings
6. Create New Profile
Connect Using: MyGlobe GPRS
7. Save Profile
8. Select the profile MyGlobe WAP in Internet Profile
9. Click Right Soft Key to Choose More and Select Settings
Internet Mode: HTTP
Use Proxy: Yes
Proxy Address: 203.177.042.214
Port Number: 8080
10. Save Settings and repeat Step 9 but this time choose Advance Settings
11. Change Homepage
Title: MyGlobe
Address: http://www.globe.com.ph/globe.asp
12. Save Changes
MyGlobe Internet Settings
3. Create New Account. GPRS / PS Data
Account Name: MyGlobe INTERNET
APN: internet.globe.com.ph
4. Save Account
MyGlobe MMS Settings
1. Go to Menu>Choose Settings>Connectivity
Account Name: MyGlobe MMS
APN: mms.globe.com.ph
4. Save Account
Connect Using: MyGlobe MMS
7. Save Profile
8. Select the profile MyGlobe MMS in Internet Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings
11. Click Right Soft Key to Choose More and Select Advance Settings
12. Change Homepage. Enter the following parameters and save the settings
Address: http://192.40.100.22:10021/mmsc
13. Go to Messaging>Settings> Picture Message
14. Edit Message Server : http://192.40.100.22:100.21/mmsc
15. From Message Settings, make your Internet Profile: MyGlobe MMS
MyGlobe Stream Settings
3. Create New Account. GPRS/PS Data
Account Name: MyGlobe Stream
APN: real.globe.com.ph
4. Save Account
5. Go to Streaming Settings
6. Make MyGlobe Stream your default APN.
2helpful
How to open Globe gprs to Nokia 6303
GPRS SETTINGS
4. Save Account
7. Save Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
11. Change Homepage
Title: MyGlobe
12. Save Changes
4. Save Account
4. Save Account
7. Save Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings
4. Save Account
Connect Using: MyGlobe Stream
2004 Accord; aftermarket headlamp blows
Is the globe blowing from overcharging ,vibration,excessive heat or poor quality globes.Take the globe to a auto electrician and they may be able to identify cause.The globe is easy to fit in upside down and if not seated properly can overheat.Alternators are starting to fail on these vehicles also,no aftermarket parts or alternators are available as of yet.Around $1400 for one from Honda.The most likely cause is poor quality globes or loose in globe holder.Fit brands such as Phillips or Tungsram.
Good Luck!!
1helpful
We're thinking of buying a new motor on this 10-year old machine. Is it worth it at half the cost of a new machine? What's the next most likely part to fail?
AT 10 years old, anything is likely to fail, bearing in mind that every moving part has had 10 years use.
I personally would purchase a new appliance, for one thing , you are starting off with a guarantee on the whole appliance, as the only guarantee on repairing your other one , would be on the motor.
Get that replaced, and next week, something else could go wrong.
Hope this helps to make up your mind
Can't get my commercial hot tub heater to fire up
It sounds like this is in your circut board and I could not begin to tell you how to check this without tools and diagostnic equip. Sorry but it may be time for a pro. Good luck
1helpful
2answers
10 amp fuse blows when you turn on tail lights
Check your tail lites to see if you have rust or a grounding on the hot side of the wire seating or the wrong bulb or wrong fuse.
Top Olympia Lands Phones Experts
k24674
Are you an Olympia Lands Phone Expert? Answer questions, earn points and help others
