How do i catch the bobbin thread
SOURCE: needle picks up bobbin thread but then thread gets stuck
I've had similar problems (as well as other problem with the thread breaking all the time and the "shuttle race" thing that holds the bobbin falling out. One very important thing that isn't mentioned in the manual but that the salesman stressed is that you have to use only "Schmetz" brand needles. They are a tiny bit longer, but that makes all the difference in the world if your stitches are skipping. I forgot and used Singer needles and had horrible results.
SOURCE: Unable to get bobbin to pick up thread from needle.
Check the thread coming out from the bobbins maybe on reverse side,also check the bobbins tension adjust it there is a small adjusting screw.Check also the needle alignment lastly check the upper tension from the tension regulator knob,tension adjustment is depend on the fabrics that you sew.
SOURCE: can not get bobbin to thread
Ok, while I can't find your exact model, I found the closest number for threading/bobbin instructions:
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_4795_threading_Diagram.htm
And this site has instructions for many more Necchi machines:
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
SOURCE: 6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
