SOURCE: SAMSUNG 32 IN LCD LE32R73BDX (MASTER RESET)
* With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
* The TV will turn On with the Service Menu displayed.
go to reset
* Press the {POWER} button to exit the Service Menu.
SOURCE: LCD TV flickers non-stop
More likely to be bad LCD controller, see sample here: notes: I removed the cover from the board. http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Parts: there are more than one version of the board, http://www.shopjimmy.com/catalogsearch/result/index/?q=LTV-32W3HD&stock=all
Be careful when remove the back cover! the switch assembly is attached to the back panel, do not yank too kard to remove the back.
SOURCE: i connected dvd player to dynex 32 inch tv. what
You should be connected to the AV input 1 slot. Change the input on the TV to Input 1
SOURCE: My sharp aquos 32' LCD has a heavy green tint to
My sharp tv also had a green tint and resetting to facotry setting did not work, what finally worked is making sure that all cables were inserted all the way into the tv and receiver. Someone else advised this for another Tv and it worked on my sharp so it is worth a try.
SOURCE: I have a Sharp 32 inch LCD TV (LC-C3234U)that sits
Try the head phone jack there are some kool remote systems out that support the head phone output.
you can also place them anywhere in the room.
Testimonial: "very helpful!"
