Remove apps & clean out memory space. Then download and reinstall. Or you may be able to add a larger external memory card.
SOURCE: I getting error every time I try to install a apps
Remember not just any fone can google play especially not BBerry
SOURCE: Google play on my lgl75c v. 2.3.4 will not
Sign in to google then go to play store, it should then recognise your existing accounts and history.
SOURCE: i have an irulu tablet. I inserted a 32gb sd
Most apps do not natively install to an SD card when downloaded from the play store. You have to have an app like AppManager, that has a function to 'move' apps from internal storage to an SD card, or use a manual option in the Android Settings section to move each app individually.. If you are that tight on space that you cannot load any new app, you may have to delete or move something from your internal storage so you can download AppManager or some similar app, and then move as many apps as you can to your SD card. If you have a lot of photos and music you can try moving that to the SD card if your player/viewer software will allow you to find it there. Best way to move bulk items (music/photos, not apps) is to connect to a PC through USB, which brings up your internal storage and the SD card as external USB storage items. Then copy from internal storage to SD card through your PC. Best to establish folders on the SD card to hold these items and then tell your app where they are.
