How can I fix the error I am receiving at initial start up? See details section for Error and description of what has already been done to try and fix.
Error message showing up on black screen:
Intel UNDI, PXE-2.1 (build 083) Copyright (C) 1997-2000 Intel Corporation
This product is covered by one or more of the following patents: US6,570,884 US6,115,776 and US6,327,625
Realtek PCIe FE Family Controller Series v1.33 (08/08/13) PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE Rom
Reboot and Select proper Boot device or insert Boot Media in selected Boot device and press a key
I have checked the Boot order by pressing F2 at initial start up to check the set up. The boot order follows the same order as another one of the laptops that is the exact make and model. I have checked the Boot Options using F12 and what I found peculiar there is that my good machine shows The following for Legacy Options: Hard Drive, CD/DVD/CD-RW Device, Network. Whereas the machine with the problems only shows the following for Legacy Options: CD/DVD/CD-RW/Device, Network
Re: How can I fix the error I am receiving at initial...
It sounds like the hard drive in your machine has failed. It uses a standard 2.5" SATA hard drive (Most likely 9.5mm thickness maximum, most are that.) Hopefully you have made a recovery CD set from the recovery partition on the drive.
Unfortunately this is a very confusing error, and one that does not really have a simple to write out answer. libiomp5.dll is a newer way of Intel accessing webcams, while libguide_40.dll is the old way of doing it. For some reason there is already a program using the older version of the file when your webcam program attempts to initiate the newer method. What program are you trying to use?
use the phone activation procedure... if u still having problem contact customer service and they will help if they cant help they transfer u to someone else who can help if u still having problem at this point they give u a new product key...
Maintenance item No. U021 Memory initializing Description Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history and mode setting. Also initializes backup RAM according to region specification selected in maintenance item U252 Setting the destination. Refer to *1 of the maintenance mode item list about the item initialized. Purpose To return the machine settings to their factory default. Method 1. Press the start key. 2. Press [EXECUTE] on the touch panel. 3. Press the start key. All data other than that for adjustments due to variations between machines is initial- ized based on the destination setting. 4. Turn the main power switch off and on. For errors occurred, turn main power switch off then on, and execute initialization. Error codes U024 HDD formatting Description Initializes the hard disk. In addition, the following settings are also initialized by initializing the hard disk. System menu (user login administration, job accounting, address book, one-touch keys and document box etc.), shortcuts and panel programs Purpose To initialize the hard disk when replacing the hard disk after shipping. Method 1. Press the start key. 2. Press [EXECUTE] on the touch panel. 3. Press the start key to initialize the hard disk. 4. Turn the main power switch off and on. Description Codes Description 01 Configuration initialization error 02 Counter initialization error 20 Engine initialization error 40 Scanner initialization error 2JZ/2JX/2JV/2H7-5 1-3-23
This may sound stupid but make sure it is plugged in. Check the operating system and hardware requirements, if they don't meet the requirements, software will not recognize the device. Try different usb ports because sometimes computers have selective hearing and make sure your computer is initially recognizing the device when it is plugged in. If all else fails, don't try to install the software and head over to computer/my computer in the start menu. Right click and select properties. Click device manager in the hardware section or the bar to the left and look in the cd drive section. If you see your drive, right click and try any option about installing.
this error is related to fixing unit problem try this press * with head 2&8* with head on the LCD panel press Copier>function >clear>err> ok Switch off/on the machine or check the main AC supply if it is stable or not. hope this helps
Description of Problem 100000018247
When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
Description of Solution 200000023257
You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
1. Press the MENU key.
2. Press the UP OR DOWN ARROW key to select Fax.
3. Press the OK key to confirm your choice.
4. Press the UP OR DOWN ARROW key to select Print Fax.
5. Press OK.
6. Press the BLACK START key.
- Your Brother machine will print the stored faxes.
7. Press the STOP/EXIT key to exit the menu.
8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
Your Profex likely has a dead NiCD battery. You are getting this error because this battery maintains your personal effect settings on an SRAM chip that requires constant power to "live". You can try reinitializing the SRAM on your unit by doing the following:
1. Power off your Profex. 2. Press and Hold the "PLAY" and "GLOBAL" buttons while powering the unit on. 3. You should see a message on the display that reads "MEMORY INITIALIZED". Afterwards the Profex should act normal. 4. If your internal battery is getting low or is already dead, it is going to start leaking (if it hasn't already). YOU NEED TO GET THAT BATTERY CHANGED NOW!!!!! If enough battery acid leaks onto the circuit board, it will ruin your Profex forever.
