If control panel is open,close&push until locked,how to solve?
SOURCE: How can I solve error E214 of my canon 6260 photocopier
The error code deals with the scaner / mirrors or lamp. When you turn the copier "ON" will the scanning lamp turn on? If not your Lamp is blown or it could be the thermal fuse for the lamp, but it is most likely the lamp. It could also, mean that the Lens is not moving into home position.
SOURCE: alarm flashing and saying cover open. Have opened
canon.com your close door switch has something stuck in it or it is broken
SOURCE: Canon MP830 LED Error 5100 'Inner cover is open.
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on).
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
To unlock, manually press and HOLD the open/close button & the stop button simultaneously, and HOLD them both down until the lock picture disappears. The DVD will eject when you press the open/close button.
To lock the DVD inside the machine, repeat the same step, and it will lock it inside.
