Refrigerators Logo
Posted on Jul 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water dripping from bottom of freezer casing
Water dripping from bottom of freezer causing puddle under veg. drawers. Frige is clean and cooling and freezing. Happening occasionally. 197D3168P002 Is the defrost moisture not draining properly? Can I fix this myself?
David Dishong
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 15 Answers
  • Posted on Jul 08, 2009
David Dishong
Contributor
Level 1:
Welcome Back:
Answers
15
Questions
0
Helped
5403
Points
24
Your drain line is frozen. Ice thawed by the heater in the freezer normally drains down a tube into a pan on top of the compressor, where it evaporates from compressor heat. If the drain freezes the water runs into the freezer bottom instead of the tube then into your fridge. To solve this remove everything from your freezer and remove the access panel in the back or bottom depending on your model of fridge. Turn off or unplug the appliance. Upon removing the panel(s). you will likely see that the bottom of the freezer is full of ice. Use a hair dryer or heat gun to thaw ice and remove. In the very back bottom you will uncover the drainhole. I usually use very hot water and a shop vac to thaw the drain hole. When you finally clear it you will hear water running into the pan on top of the compressor. Somethimes it takes a lot of hot water to clear the drain. Hope this helps!
John Tripp
Level 3:
  • GE Master 4,656 Answers
John Tripp
GE Master
Level 3:
Answers
4656
Questions
Helped
1679037
Points
14883
Most likely your freezer drain is block by Ice or something has blocked the drainline downline from freezer. Here are a couple reasons for this. click the links below. Sea Breeze
kitchenaid
-top-mount-refrigerators/">http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://appliancejunk.com/forums/index.php?topic=22.0
And visit My sites, Thank YOU, Sea Breeze=> http://servicepartstec.blogspot.com/
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
I have ice bottom of freezer
There could be blocked condensate drain and water from the freezer is dripping in the refrigerator and freezing under the crispers.
Magic chef frost free refrigerator leaking water down the rear appears to be coming from the freezer compartment water puddles under veg. bin and then out onto the floor do not see a drain hole in...
Generally you have to remove the back panel of the freezer. There you will find the freezer coil and fan. the defrost water drips off the coil during defrost and gravity flows down thru the drain. Hole should be in center of unit. Those drains plug up. clear drain.and make sure panels go back on correctly
Water is pooling under veg drawers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
A lot of water collects in the ridge under the veg-fruit crispers. I have to constantly sop it up with towels. This model does not have a drip tray under the storage area
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
I have water dripping from the freezer into the refrigerator and refreezing in the drawers. How can I find where the water is coming from and correct the problem?
It is leaking due to a clogged drain line between the bottom-rear of the freezer section and the drain pan underneath the refrigerator. Remove cover in the back of the freezer section. there will be a small drain pan under the cooling coil. Remove ice, defrost with hot water and clean/blow the drain line.
Integrated fridge freezer growing iceberg..
problem could be one of two things.
insulation breakdown will cause an iceball to form.
if the compressor is failing, then frost line does not reach the thermostat poisition and compressor runs all time and an ice ball will also build up
in either case, not worth repair
Tube to ice-maker leaks into refrigerator
try make sure that its balance. it could be off level
Top Refrigerators Experts
vince
Johnny 1000
