Having problems with the chain saw 028 AV Super Stihl need fuel system diagram
Http://www.mediafire.com/view/czbi0jaqff2bzd5
here is the parts diagram
SOURCE: owners manual for a Stihl 034 AV Chain saw
Stihl Manuals
http://www.stihlusa.com/information/info_product2.html
For an IPL you must contact them.
HTH
Lou
SOURCE: i need a fuel hose diagram for a stihl model 028
Stihl IPLs (exploded parts list) are propriatary, You can request one here: The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but on multiple illustrations.
http://www.stihlusa.com/contact.php
Typical Fuel System (Primer Bulb and fuel lines may not apply)
http://www.img4free.com/images/Lou98321/fuelsystem.jpg
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
SOURCE: is there supposed to be a cyntrifical clutch on a
Yes; see page 37 in your OM. You read it before using your saw right?
http://www.stihlusa.com/stihl_ownersmanuals/STIHL028_with_safety_manual.pdf
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
SOURCE: stihl 038 av super chain
Afternoon Mac;
I am going to give you a qualified YES.
It is possible with Husqvarna and Echo.
All Stihl parts are proprietary and new OEM parts must be purchased through a local Stihl dealer. A phone call to your local store will answer your question and whether they have one in stock. If you do not want to utilize your local dealer eBay for a used part is your best option.
If you have more questions or need additional help please reply below and I will get back to you. HTH
SOURCE: I have a Stihl 028
Just remove the spark plug, connect the wire, and lay the plug base on engine metal. Turn on the ignition and pull the starter. If nothing, first try a fresh plug gapped at 0.020". If still nothing, service on the ignition system is required. Suggest finding a Stihl service dealer if you don't have mechanical service skills. Hope this helps!
Find the adjustment screws marked H and L. Turn the one marked with an H an 1/8th of a turn CCW till it revs up properly
