Whirlpool Duet GHW9150P Front Load Washer Logo
A
Anonymous Posted on Feb 23, 2015
Why does the fabric softener not dispense in my Whirlpool front load washing machine?
Andrea Szabo
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jul 04, 2015
Andrea Szabo
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2592
Points
28
If I recall there is a kind of latch or tongue on the bottom of the tray. You need to push it upward from the underside and it will unhook and the tray will slide out.
5 Related Answers
Anonymous
  • Posted on Feb 07, 2009
SOURCE: fabric softener dispensing before wash begins
I was having the same problem. Repair man replaced VALVE AW
He told me it is from the sedement in your water. If you have a water softner, it may not be the problem, unless it is not working properly. Sounds strange, but problem is fixed.
Anonymous
  • Posted on Apr 03, 2009
SOURCE: Whirlpool Duet dispenser problem
I had the same problem my fabric softener would not dispense.Close shut-off valves and take off the water hoses off the back of the washer and look for blockage on the screen.Mine was plugged up and after cleaning it off it works like new.
Anonymous
  • Posted on Sep 20, 2009
SOURCE: whirlpool washer fabric softener dispenser
The fabric softener dispenser in my Whirlpool washing machine is caked w/hair and detergent. I have tried to take it out by unscrewing it, but it won't come out. What's the secret? Please help!
Anonymous
  • 129 Answers
  • Posted on Feb 04, 2010
SOURCE: Fabric softener is not dispensing
drain tube stopped up with softener needs cleaning
Kolbrun Gunnarsdottir
  • 1228 Answers
  • Posted on Mar 24, 2012
SOURCE: whirlpool duet washer fabric softener dispenser does not empty
Hi there
I wonder why, mine does though I never use a fabric softener, the water just runs through. It must be clogged somewhere, the only solution I have is the old one. The needle and the thread,try puting a needle through then pull the thread back and forth.
I hope it works
kolbrun
1helpful
My soap dispenser does not clean out. ie fabric softener compartment does not rinse all of the fabric solution out.
Hi, remove the dispenser draw and clean out, you'll probably find a load of unused soap and softener gunked up in it
Front loadrer will not pull fabric softener when the rinse cycle begins.
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
The soap dispenser works but the bleach and softener dispensers do not
heatman101
Whirlpool washer fabric softener dispenser cleaning
Fabric softener and bleach dispensers
Call the tech. one came out this week and said the system solenoid is always engaged causing the bleach and detergent to dispense when drawer is pushed in
1helpful
Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
