Yamaha Ef3000iseb Generator Portable 3000 Watt Rv Motorhome Camping Trailer Logo
A
Anonymous Posted on Feb 23, 2015
Able to start but will not continue to run. Already checked fuel line and float, gas is flowing to carb. but will not stay running?
Cleaned fuel tank and filter also took off fuel float bowel and cleaned
Renee F
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Yamaha Expert 573 Answers
  • Posted on Mar 01, 2015
Renee F
Yamaha Expert
Level 2:
Prodigy:
Answers
573
Questions
0
Helped
247869
Points
680
Sounds like gummed carb, you may have to pull apart and clean the jets.
I just bought a mud blaster 110cc quad for my son, why does it start then 2 min later stop even with feathering the throttle?
#1 sounds like a fuel delivery system issue. Make sure the fuel tank flows freely to the carb. (remove the fuel line from the carb--from the gas tank and turn on the petcock--gas should flow freely) The needle and seat may need to be cleaned or replaced, this controls the flow of gas into the float bowl of the carb.(remove the drain screw from the bottom of the carb (with everything properly assembled- petcock on)..gas should continually flow through the bottom of the carb --10-15 seconds of continual gas flow will make sure its flowing properly! Both of these sound like a solution to your problem.
Jun 22, 2014 • ATVs
Craftsman chain saw 358.350870 starts but will not continue to run
look for gas tank vent. if clogged it will cause a vacuum in the gas tank and not let gas flow to Carb.
Dec 17, 2012 • Garden
2answers
Snapper Big Six Mower. New spark plug, cleaned carburetor&fuel tank, new 91 octane fuel mower starts with engine starting fluid but won't stay running
Try taking the float bowl off and clean out the orfus. It will eather be in the nut holding the bowl on or in the end (sides) of the pickup tub the nut scews on.
2helpful
3answers
Fuel problem with John Deere 23hp engine
time to pull the hose off the fuel pump coming from the tank and drain the tank and check flow of gas coming from tank hose, and possibly inline fuel filter is plugged or there is junk in your tank/line from tank not letting enough fuel to run to pump so pump can pump it to carb !
Have a Speed Clean 2000 PSI Pressure Washer with B&S 3.75 Enigine that will not stay running. The unit will start and run for 30-45 seconds then stops. Can keep the engine running a little longer if I
the problem is with the carb. not able to keep enough fuel going into the float bowl to support engine staying running. could be hose off gas tank clogged or petcock, coud be main jet sticking closed or float level out of adjsutment.
Dec 17, 2011 • Garden
2003 polaris magnum 330 i have cleaned the carb, gas hose to the carb i also cleaned. when ever i start it the only way it runs is with the choke on and no gas is pouring out of the gas line and the t
Sounds like contamination has set into the fuel shutoff valve on the bottom of the fuel tank, or the fuel cap vent hole is plugged. Test the fuel line that comes from the fuel tank. First turn the valve off, disconnect the fuel line that feeds the carb, insert the fuel line into clear small container, then open the fuel valve to the on position and look for fuel flow,now turn the valve to the reserve position and check again for fuel flow. If these test fail to yield fuel try the procedure again this time with the fuel tank cap loosened and check for fuel flow. If in both tests the fuel fails to flow then the problem can be isolated to the fuel valve/tank outlets or the fuel line to the carb.
Dec 09, 2011 • Polaris ATV
2helpful
I have a 2001 Suzuki Maurader 250 - we bought it used and cannot get it to start - we have had it running but the next day it will not start. |We have changed the oil, plugs, cleaned the carb and now it...
Drain the carb with the gas valve on the tank turned off. Now turn the valve back on and see if gas again begins to flow out of the float bowl. If no gas drains with the valve open then remove the fuel line at the carb and check to see that fuel flows freely through the fuel line. If gas flows freely out of the fuel line then the float needle is stuck closed or trash is plugging up the needle jet assembly. If so, remove the float bowl and free up the needle. Use spray carb cleaner and the little "straw" that comes with the can to direct the spray into the float needle fitting. Fuel should flow when the float is down and stop flowing when the float is lifted. Pull a spark plug and ground the metal against the cylinder. Check for spark. If there is no spark then check the operation of the kill switch on the side stand and the handlebar. Use a multimeter to check the switches. Get fresh gas and install an in-line fuel filter to keep any trash out of the carb. Clean the air filter. Please rate my answer. Thanks.
Ran out of gas then problem started gas leaks out of carb and over flow line vent or float problem
You will need to remove and clean the carb. When you run one out of fuel it allows all the trash in the tank to go into the carb. The fuel leaking from the overflow is trash in the float needle and needs to be cleaned.
I have a craftsman 2200 psi 6.75 hp Pressure washer. Model#580762202/Serial# 5003874. I had it sitting for about a year. When I tried to start it nothing happens. But when I spray gas in the carb and pull...
Did you check fuel tank and feed line to carburetor for dirt/obstructions?
Screen inside tank at fuel line connection may be plugged. Pull feed line off at carburetor and see what kind of flow your getting from the tank. I will assume you checked fuel inlet port of carb when you had it off to clean.
Jun 27, 2010 • Garden
Lawnmower starts but won't run-replaced airfilter and plug cleaned carb
If it is starting and not continuing to run it still sounds as though something is blocking the fuel flow. If the carb has been cleaned out, literally torn down and the needles cleaned so that no small debris is clogging them, check the fuel tank and lines for anything that could be restricting the flow to the engine. Remember that it's recommended that you replace the fuel line (cheap fix) when you dismantle the carb. Removing the line breaks off small pieces of the rubber in a worn line, which can re-block a freshly cleaned carb.
May 12, 2009 • Garden
Top Yamaha Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
MrFixitSTTL
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
