Question about Philips Magnavox 27MS343S 27" TV
How do I make screen brighter bt using remote
What is the code for the BT YouView remote to a Celcus flat screen TV?
The codes are here. Doesn't matter if it is Virgin or BT, the code is to the television not to the remote.
http://celcustv.co.uk/faq
Jun 17, 2016 | Celcus Televison & Video
I operate my TV with the convertor box remote control, how can i get a brighter picture using the remote control?
Most converter boxes will not perform that function unless you have a menu on the screen.
Jan 28, 2015 | Televison & Video
Bt error
Put in fresh batteries. You have to pair the querty side of the remote again. Go up to your samsung smart TV 8 inches or less to pair. Press SYM and TAB at the same time. You should notice on the querty screen that states "Pairing." Your TV should confirm. The keyboard will load up when you press a key. Follow information on TV screen. Some applications like Netflix do not work with the remote. You can use your Querty side when you press on an app. Scroll to any app. If a screen pops up like for web browsing just type like a keyboard.
Dec 06, 2013 | Samsung BN59-01134B Remote Control...
Technika codes please for 40'' screen
Consult the owner manual (or Google the model of it for manual) but not all remotes will program for all sets and even if do will not have all the needed or wanted features the original remote has.
Nov 08, 2012 | Hitachi Televison & Video
Tv problem
hii actualy I just want to confirm tht my tv is powering off after every 10 minutes I tried bt I didn't find any reason
Sep 08, 2012 | Hitachi Used Original L55S604 Remote...
I have an e-motion tv and am unable to set my bt vision controler up as can't find a code
Same problem solved through patient "trial & error" ... for my e-motion TV, the BT Vision remote works with code "0081"
To program the BT Vision remote, instructions can be found at:
http://bt.custhelp.com/app/answers/detail/a_id/13573/~/programming-my-black-bt-vision-remote-control
Mar 06, 2012 | Televison & Video
Kenwood KVT911
kvt 911 screen does not pop up you have to manually flip it once it's deployed out.
Aug 28, 2008 | Car Audio & Video
Bt vision remote
www.remotecodelist.com .....................................T.
Mar 20, 2008 | Televison & Video
Remote control
the code for the bt.vision box remote to work a durabrand tv is under the emerson range the code i used was 004 it works fine
Oct 10, 2007 | Durabrand DU1901 TV
Philips Magnavox 27MS343S 27" TV Logo
76 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
