SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
SOURCE: kenmore chest freezer power problem
Try to unplug the the unit power supply to reset the error. But if the error persist you have to call for a qualified technician,
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
SOURCE: my kenmore freezer does not turn on at all
u either need a new thermostat or your compressor is dead
Their web site is partselect.com. Site has an "instant repairman" tab
Good luck
