Apple iPad 64 GB 3G Tablet PC Logo
y
yvonne kriel Posted on Feb 23, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i insert the sim card in an apple ipad 64gug
Trevor Campbell
Level 2:
Scholar:
New Friend:
  • Expert 115 Answers
  • Posted on Apr 24, 2015
Trevor Campbell
Expert
Level 2:
Scholar:
New Friend:
Answers
115
Questions
0
Helped
15890
Points
249
If your Ipad is a 3g enabled option then go to the follwing link for instructions: Remove the SIM card from your iPhone or iPad instead of removing it you just put it in.
Sim card for Apple iPad 1st Generation 16GB, Wi-Fi, 9.7in
it will probably be a mini sim card available from any phone shop or service provider shop.
1helpful
2answers
How to unlock ipad2 puk code
Your iPad 2 must have 3G, with a sim card. For the sim you need the pin and after 3 misses you need the puk. The puk is on the letter or card that came with the original sim card. On that letter is the pin and puk. sometimes you have to scratch away the metal layer.
If you want to unlock an iPad, with the lock code on, and forgot your pass code you have to enter the correct password that belongs to your Apple ID. It will be partially on the screen. If you really messed up, setting up security, and lost unlock code and your Apple ID password. Only Apple can help. For that you have to take iPad, invoice, Prove of your identity (Passport) to the Apple store and hope they will unlock your iPad. With iOS7 Apple mede a very good security system. And while setting up the iPad and the security, you are warned several times what to do t make sure you and only you could enter the system.
Be aware if Apple does reset your iPad, all data now on the iPad will be lost.
How i can put simcard show vedeo
1) you state the problem is with an Apple iPad 32gb Wifi Tablet. You will be unable to put a sim card in as this is not the 3G / 4G version.
2) Refer to the original product documentation.
3) Have you searched the manufacture website? There are online user guides on apple.com.
4) Use a small needle and press it in to the hole on the sim card slot. remove, insert your simcard and insert in to the ipad.
How can I insert a SIM card on a1458
The a1458 is a wifi only model. There is no way to add a SIM Card.
Where to insert iPad sim
SIM card insert is on side of iPad with 3G,if not 3G it will not have a slot.
1helpful
2answers
My sim card not installed
It may be a case of wrong cutting of the micro sim. Since the iPad uses a microsim, you haveto make sure that the sim card is cut perfectly. Do not use a pair of scissors, you have to cut it specifically using a micro sim cutter. Or you can check if the placement of the sim card is correct. Sometimes, the card seems to get loose thus making it unreadable by the iPad.
1helpful
How to insert a sim
Hi, on the wifi version of iPad. You cannot insert a sim on this unit. The 3G units has a slot for micro sim cards. The wifi version does not have the hardware inside necessary to access 3G networks.
Sorry
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
