A4tech PK-635 Webcam Logo
A
Anonymous Posted on Feb 23, 2015
How can i replace with a usb plug because it has 8 wires inside, but i found a usb plug it has only 4 wires.. i dont know where is the D+ and D- and the positive and negative .. please help
Wire has been accidentally cut and USB plug missing
Can I change ge scroll mouse plug to usb? There is 5 wires on usb end and 4 wires on ps end.
Theoritical it's possible, but i dont know what cable to go where. An adapter is worh its money!!
2answers
Need to know the order the plug wires hook into the coils on a 2000 Mercury Mountaineer 5.0
here is the firing order for the 5.0 as well as what goes where; firing order 1-3-7-2-6-5-4-8
2helpful
Got the wires crossed, need to know what nu goes where,i dont know which wire goes where.
if its a v8,,the fire ring order is 1-8-4-3-6-5-7-2-,,drivers side,looking at side of motor from fender,,left is # 1-# 3-# 5-# 7,going left to right,,passenger side looking from fender at motor,,first plug right side #2 # 4 # 6 # 8,going right to felt,,hope it helped,,,
3answers
I need to replace my floppy drive on a yamaha psr 9000 keyboard
Why.. get a USB floppy.. if you go inside a PC and pull a wrong wire your PC will be toast. Get a USB floppy. Why are you using floppies anyway? Get a USB stick for $8, way less then a replacement floppy and much safer.
2helpful
I am trying to hook up front panel usb ports.
check out this diagram i think it might help you
http://attachments.techguy.org/attachments/107266d1180693321/standard-usb-pinout2.gif
or if the link is unavailable then here is the same info
pins 1,3,5,and 7 are one usb connection
pin 1 = +5V
pin 3 = D-
pin 5 = D+
pin 7 = GND
pins 2,4,6,and 8 are another usb connection
pin 2 = +5V
pin 4 = D-
pin 6 = D+
pin 8 = GND
pin 10 is not used
Plugging in a USB port.
You have an A side and B side, or 1 and 2. Starting from pin 1, usually has an arrow pointing to it, the wires should read as follows: 1= A/1 +5vac 2= B/2 +5vac
3= A/1 -D 4= B/2 -D
5= A/1 +D 6= B/2 +D
7= A/1 ground 8= B/2 ground
9= no pin 10= no connection
Damaged usb port needs to be replaced on my HP Pavillion 513W computer. Need diagrams and step by step instructions
1-Shut down you pc .2-unplug the power cord.3-open the case .4-Find the usb wires trac them back to the board. 5-mark were the wires go with a marker.6-plug new usb port wires in.7-put the case back on pc.8-plug power cord in.9-turn on pc.10-plug your usb device in.
6helpful
4answers
Front usb connections
I finally found a solution, on a dead page in google cache only:
http://www.pcclub.com/forum/messageview.cfm?catid=27%26threadid=16567
The solution was posted by JontyBonkers.
The pins go like this:
1 2 3 4 5
_ 6 7 _ 8
1 = ground
2 = ground
3 = D1-
4 = ground
5 = D1+
6 = D2-
7 = D2+
8 = +5V
It seems that the case for those Packard-Bells had a small circuit board that divided the 5V line to both sockets.
D- are usually white, D+ - green, 5V - red, ground - black
6helpful
3answers
Havimg prob with the 2 usb ports located in front
Hi manky, Normally front USB ports have a pair of 4 wire cable with connectors marked red wire is vcc; white wire is -D; green wire is +D; and black wire is gnd. The motherboard would normally have two pairs of dual pin connectors that would be sitting side by side or in-line with uneven pins - 4 and 5 pins; then another 4 and 5 pins. Please refer to the attached simple diagram for your connection. For some reason I couldn't get hold of a manual from the Gigabyte site of your particular model GA-81KHXT. Nonetheless hopes this works for you. Pls post again how things turn up. Good luck and kind regards.
Top A4tech Computers & Internet Experts
k24674
ExpressFiX
ExpressFiX
Steve Sweetleaf
Steve Sweetleaf
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
