That's it, why such wet clothes, normal heavy wash, only used 3 times. Not happy. There better not be a charge for this help or I will need to call Whirlpool corp.
SOURCE: Roper washer ras7133kq1will not spin enough to wring out clothes
bad motor most likely. easy fix
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
SOURCE: On delicate cycle clothes wringing wet when done
check drain hose kink or belt adjustment...worn clutch...basket drive
SOURCE: Whirlpool washing machine AWO/D 4305 does not spin
its probably an inbalanced load or its to light.it MUST have a good full mixed load to spin
