Door is rubbing on the bottom of the inside of the refrigerator and not closing!!
SOURCE: freezer door rubbing
take the freezer door off and put a washer or two on the bottom hinge. sometimes there are extra plastic washers on the top hinge that you can move to the bottom to lift it up.
also check if the hinge is bent or loose, as this may cause the problem.
SOURCE: Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
SOURCE: My refrigerator gurgles when the bottom freezer door is closed?
Air is stabilizing between the fridge and freezer.
Do not worry.
SOURCE: Door is rubbing at the bottom of fridge. Can it be adjusted?
there is a kit that goes at the bottom hinge that will lift the door
SOURCE: hoover contour fridge leaking
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
Testimonial: "thanks, all fixed!!"
