At manualslib.com
Two manuals are currently available for our unit
Results 1 11 of 11
Install:
Kenwood KFC 1633MRW Installation Instructions Manual
Owners operation manual
Kenwood KDC X396 Manuals
Hope this helps
Carnac the Magnificent
SOURCE: clock
you have to get into the menu. Here is a link to the manual to help you do it. http://inform2.kenwoodusa.com/manuals/KDC1028.pdf
SOURCE: aftermarket stereo install
Was it working before?
I would hate to have you crack it open when maybe the ground wires arent hooked up right. Unless you have a scope go online and get the manual on wiring it to ensure you did it right.
SOURCE: Kenwood KDC-138 Operation Problem
Here's the quote from the manual regarding "dcer": "The speaker wire has a short-circuit or touches the chassis of the vehicle and then the protection function is activated. Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT/DCER" code does not disappear, consult your nearest service center "
I believe the manual can be downloaded from crutchfield .com after you go to the Kenwood KDC-138 page on their website. The reset button is either on the lower left of the face or, removing the face, on the lower left of the body. Hope this helps you.
SOURCE: 2005 jeep grand cherokee laredo aftermarket CD player installation
Unsightly gaps as in how?? I know the kits anymore give you, usually, diferent mounting depths and whatnot. You get alot more pieces than needed but options are always good! This I know was true with the GM/Pontiac kit I just installed for my stepfather. Looks good, doesnt protrude any, other than just the face!
SOURCE: installing kenwood kdc-mp238 in a 2001 dodge ram 2500 quad cab
No ur radio is fine to fit the wiring harness into ur dodge the wiring has been crossed so it wont work, if u go 2 the Kenwood US site and down load the KDC MP 228 manual it has a good wiring dirgram and with a bit of work u can work out what goes where :0 Hope this helps
